Old 05-28-2011, 03:51 PM   #1
1974 27' Overlander
Fair Oaks Ranch , Texas
Water heater cabinet cover to 1974 Overlander
I am a new owner and am in progress with many small repairs, but this is one that seems mystifying. The previous owner replaced the WH with a 6 gal Atwood, but the interior cabinet piece covering the pipes, next to the toilet in the center bath, is missing, it appear to be made of formed plastic and has a vent to heater. Anybody with any idea what it is called or where I can get it, I would sure appreciate it!
Kevin
GeoStreamer is offline   Reply With Quote
Old 05-28-2011, 03:59 PM   #2
1974 27' Overlander
I found this photo on Balrgn's post
Old 05-29-2011, 09:17 PM   #3
Kevin,
Our 1979 has the same plastic shroud minus the vent. Hopefully someone will speak up and may know where to get a replacement. You also may want to check with people parting out the inside of a center bath as that may be the only source for it. Being that our 1979 center bath has the same shroud, there may be many years the same shroud was used, making your search easier.
Old 05-30-2011, 01:35 PM   #4
1974 27' Overlander
Thanks for the info, that looks to be the same and may work for us, just need to figure out the part no.
Appreciate the help.
Water heater won't lite imuir Water Heaters, Filters & Pumps 6 06-06-2011 10:18 PM
Water Heater Calcium Deposits -- What to do? roscher Water Heaters, Filters & Pumps 7 05-18-2011 04:11 PM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 08:27 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
