Old 02-09-2016, 12:06 PM   #1
1978 31' Sovereign
GRAND CANYON , Arizona
Wardrobe door hinges
Hello folks, hoping someone in this forum has already gone through this and may be able to lead me to a source.
Unfortunately, the Interstate Highway system in Texas bounced our '78 31 foot Sovereign hard enough to cause two of the three Wardrobe Closet doors to break their hinges. These are special hinges that I have not been able to locate from any RV Dealer, Airstream Dealer or even the Vintage RV site. I've attached a photo of both the top and bottom hinges from the one door that still remains. The two that broke are are 1 Right swing and 1 Left Swing.
Any help will be appreciated.
Radio Guy
Name:	1978 Airsteam Wardrobe Door Bottom Hinge.jpg
ID:	257077   Click image for larger version
Name:	1978 Airsteam Wardrobe Door Top Hinge.jpg
RadioGuy is offline   Reply With Quote
Old 02-09-2016, 02:49 PM   #2
2007 22' International CCD
Look at the Rockler Woodworking catalog hinges for a possible match. Www.rockler.com. More hinges than you can shake a stick at. Also try the big box home store hardware department like Home Depot. Lowes. Etc. Also Ace hardware.
It looks like a standard hinge.
Rockler also has retail stores.
KE4GNK/AE
Multiple Yaesu Radios inside and many antennae sprouting from roof, ProPride hitch
Old 02-09-2016, 05:49 PM   #3
1998 19' Bambi
Parkville , Missouri
I have the same hinges on my Airstream Also had one break .. Looked and looked for replacement.
Finally used an unbroken on as a pattern and fabricated new ones
MoBambi is offline   Reply With Quote
Old 08-01-2016, 06:22 PM   #4
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Did you ever find replacement hinges? Looking for some myself.
thehandyman is offline   Reply With Quote
Old 08-01-2016, 06:59 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
http://odmrv.com/catalog/index.php?m...roducts_id=986
Alan
Old 08-04-2016, 02:37 PM   #6
1978 31' Sovereign
Yes I did find the exact hinges in Nickle but not in Bronze....Did not find them directly from suggestions to this post but indirectly I did get a better idea of what to search for and found them. It's been awhile now and I forget where I found them, but take comfort in knowing that they are out there. I will see if I saved a box label or something and post a new reply here if I find the company.
Old 08-04-2016, 05:06 PM   #7
1980 24' Caravelle
Got some ordered from ODM
Old 09-29-2016, 05:57 PM   #8
1978 31' Sovereign
Pivot Hinges Found
Yes, I did find them. Here they are: http://airstreamsupply.com/New-Airst...-nickel-382159
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 07:07 PM
Safari Wardrobe Door Hinges Loose Adjustment Cable Cabinets, Counter Tops & Furnishings 3 09-14-2010 07:08 AM
hinges on wardrobe losen bfwoz Cabinets, Counter Tops & Furnishings 5 10-08-2004 07:04 PM
