Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-05-2006, 12:47 AM   #1
CaddyGrn's Avatar
Profile:  1963 16' Bambi
Yreka , California
Question Vintage Moulding Question
Hi everyone. Someone has perhaps already asked this question, but I didn't find it yet.... we are restoring our 1963 Bambi (hubby is Nor-Cal Bambi) we have the new laminate on our new countertop ~ it is the edging and moulding I am not sure about. We have found some vintage looking aluminum that will fit on the counter edge... but what about between the wall and countertop? Sort of a little backsplash... the plastic (?) material that was there is too hard and icky to use again. What have any of you used? Where did you find it? Our local hardware stores and Lowe's haven't had anything to solve the problem. The material needs to be able to fit the contour of the back of the Bambi where the kitchen is located (curb side).
Appreciate any reply to help enlighten us! Thanks.
CE
CaddyGrn is offline   Reply With Quote
Old 06-05-2006, 08:14 AM   #2
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Greetings Mr. and Mrs. NorCal Bambi ~
Funny you should bring this up. Just last week I received 12' of this aluminum extrusion from Oasis RV in Tucson. It was a bear tracking this down through the factory. I had to refer one of the service dept. phone answerers to an interior shot of the 75th Anniversary Edition by Winnick so she knew what I was speaking of. It took them a week and a half just to find the stuff since it was special order. I haven't put mine on just yet. This is a shot of the original stuff. It's a dead ringer for this. Call up Don at Oasis, he'll know what you're speaking of.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 06-05-2006, 08:19 AM   #3
GreatPumpkin's Avatar
Profile:  Currently Looking...
Colville , Washington
Images: 70
Source?
How about the plastic stuff that has a pretty much identical profile? Used along the edges of the floor in my '64?
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-05-2006, 08:22 AM   #4
flyfshr's Avatar
Phoenix , Arizona
Plastic? Plastic, you say? No luck with that. Plastic will detiorate pretty quickly in our desert heat. Surprisingly enough, this stuff wasn't that expensive. Less than $3 a foot, will hold up better than plastic especially when being kicked and hit with the vacuum.
FF
WBCCI/VAC #2699
Air #10
Old 06-05-2006, 08:25 AM   #5
Images: 70
FF
Yes - but the plastic will conform to the uneven form of the wall, whereas the aluminum will not.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-05-2006, 08:31 AM   #6
flyfshr's Avatar
Phoenix , Arizona
Just how uneven is this wall? This moulding will bend around the inside curvature to the wall at my bathroom cabinet as it did originally.
FF
WBCCI/VAC #2699
Air #10
Old 06-05-2006, 08:33 AM   #7
flyfshr's Avatar
Phoenix , Arizona
...but if its plastic you need, then Outwater Plastics has about anything you can thik of, plus stuff you can't imagine.
outwater.com
FF
WBCCI/VAC #2699
Air #10
Old 06-05-2006, 10:22 AM   #8
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
moulding for table top
I'm looking for the "T" shaped molding for edging the table top and refrigerator top in my 64 Safari. Anyone have any sources for this?
It's half round with barbed “T” insert on back to fit in grove along table edge.
I can post picture if that helps
Safari64
Safari64 is offline   Reply With Quote
Old 06-05-2006, 12:29 PM   #9
flyfshr's Avatar
Phoenix , Arizona
Safari64 ~
Outwater has tons of 'T' moulding and, contrary to their name, they have it in metal. Lots of choices. I used the polished and rippled 13/16" on my galley cabinet trim and table.
FF
WBCCI/VAC #2699
Air #10
Old 06-06-2006, 11:51 PM   #10
CaddyGrn's Avatar
Yreka , California
Thanks!
FF
Thanks for the information! And especially thanks for the picture! We may try some alternatives, but we will see what we decide. Trying to get our bambi on the road! Getting closer, but still not done.
Old 06-18-2006, 12:57 AM   #11
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I don't think it's plastic...I think it's vinyl, when it gets old, early vinyls can look like plastic, they get hard and brittle. The closest thing I've come by is a rubber or vinyl 2-1/2" carpet base.
Roppe, Armstrong, Flexco, Johnsonite all make it, among others. It comes in many colors...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 06-18-2006, 10:49 PM   #12
Images: 70
Shari
Thanks Shari - I think that's a little taller than I want. I might just have to suck it up and buy the aluminum that flyfshr tracked down.(Aluminum Trim Finally Found) It looks like the same size and profile. At that price though, it will have to wait until a few other things are completed
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Vintage Trailer Insurance Stougard Insurance & Claims 33 08-01-2009 06:12 PM
Texas vintage get together Pahaska The Rally Zone 33 11-21-2005 05:23 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 07:52 AM
Vintage trailer rally 83Excella WBCCI Rallies & Events 0 08-13-2002 10:27 PM
