Old 05-16-2010, 08:01 PM   #1
Travelin' Style
2013 25' Flying Cloud
Atascadero , California
Veneer panel replacement?
Hi. Anyone know of a good source for veneer panel replacement and edge tape? I am doing some remodeling of the refrigerator cabinet in my 2006 19' Bambi. The parts book calls for Tropical Oak/White and White Liner styles. Thanks, Charles
chbocca is offline   Reply With Quote
Old 05-22-2010, 09:41 AM   #2
RichHog's Avatar
1972 23' Safari
Houston , Texas
I used Red Oak Veneer in my Tradewind and also bought 1/4" panels from a supplier here in Houston. The Red Oak closely matches the plastic woodgrains Airstream used in the mid 70's trailers. Used Minwax "Provential 215" to stain.
It was a slow process (but what isn't when you're working on an AS).
RichHog is offline   Reply With Quote
Old 05-22-2010, 09:58 AM   #3
RichHog's Avatar
1972 23' Safari
Houston , Texas
Also got edge tape from Alsa, they have different types, used the burl wood on mine
Alsa | FX Sheeting
Old 05-22-2010, 10:27 AM   #4
Travelin' Style
Tropical Oak Veneer Panels for Cabinet Remodel
Thank you! I've checked out the Alsa website and may order our refrigerator decorative panel from them. Looks like a very good source for re-modelers.
I took attached photos of our remodel in progress so you can see the Tropical Oak/White and White Liner styles, which I believe are common to the interiors of circa 2006 Safari Airstreams.
After five years of enjoying our 19 ft Bambi, we've decided to make a few changes consistent with way we use it. For one, a smaller refrigerator, which will 1) enable us to lower the current cabinet and use the top as a desk, and 2) provides a good place to mount a monitor. We chose the Dometic RM 4223 Americana, basically getting rid of freezer that was in OEM refrigerator, which we never used.
Anyway, if anyone out there knows a good source for obtaining the Tropical Oak veneer panels, please post a reply.
Thanks again.
ID:	103086   Click image for larger version
Old 05-22-2010, 03:07 PM   #5
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
I had a dealer tell me once that the material was available from Airstream. If so, it certainly would not be inexpensive
Prickly Pear is offline   Reply With Quote
Old 05-23-2010, 01:18 AM   #6
RichHog's Avatar
1972 23' Safari
Houston , Texas
I got my veneer from a place here in Houston called Hardwood Products. Might be worth a Google to look them up, maybe they stock or can tell you of the source supplier.
2006 bambi, panel replacement, veneer panel
Panel replacement tools truckasaurus Ribs, Skins & Rivets 30 03-30-2009 09:42 AM
panel replacement ? osolow Ribs, Skins & Rivets 4 01-27-2008 07:01 PM
Wind screen sealing and veneer replacement abridges01 Argosy Motorhomes 8 09-04-2006 10:05 AM
Factory panel replacement till Ribs, Skins & Rivets 4 08-13-2004 10:46 AM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
