Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-01-2006, 06:13 PM   #1
Profile:  1967 24' Tradewind
Edmond , Oklahoma
under bed storage doors on mid-60's
hi folks-
where can i find the plastic hinge for the doors for the under bed storage bin compartments? you know the ones that flip up then can slide into the compartment.
reynolds431 is offline   Reply With Quote
Old 02-01-2006, 06:38 PM   #2
65glbtrotter's Avatar
Profile:  1965 20' Globetrotter
Yakima , Washington
Images: 31
Hinges
I have a '65 Globetrotter and the hinges under the bed are metal not plastic. here are some pics.
ID:	18122   Click image for larger version
65glbtrotter is offline   Reply With Quote
Old 02-01-2006, 07:00 PM   #3
Supposititious Blue
65GT's Avatar
Profile:  Charlotte , North Carolina
Images: 26
What HE said..
Whoa! I just ran to the driveway to make sure mine was still there! Hey there fellow GT! I see you've been here a while but I'm thinking you've been awfully quiet! I concur, what you've got, I've got, but I'm guessing there's more plastic in '67's than the '65's...
If only we had a place to go that documented all the nuances of all the different years and models... Hmmm....
__
6000+ Airsteam families having fun!
1000+ Airstream Events including 500+ Rallies in 2009!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Old 02-01-2006, 07:14 PM   #4
LADYBUG
GT1963's Avatar
Profile:  1963 19' Globetrotter
2005 22' International CCD
Lakefield , ON
Images: 59
Originally Posted by reynolds431
hi folks-
If you ever find out - I do hope you will share it here - we have looked everywhere too. Our 69 has them on floor cabinet doors. Many of them were split - so we had to make a makeshift - with clear plastic that is used for marine applications window in soft cover 'Camper Tops" windows - until we can find a suitable replacement.
this is a picture of the door you can see the brown plastic hing on the top of the door. These are under the back bedroom as well. We thought of piano hinge but the space is too thin - there is just enough room to get the door through.
The one on the righ had a split almost all the way through - you can see the clear separation. The one on the left was fine.
Note we have added the brass trim - to protect the delicate edges so that the veneer does not peel any more than it had.
Gee that picture seems like eons ago....
Streaming in the spirit of Exploration...
"To go places and do things that have never
been done before-that's what living is all about."
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
GT1963 is offline   Reply With Quote
Old 02-01-2006, 08:38 PM   #5
Profile:  1969 31' Sovereign
Elizabeth , Colorado
I'm thinking of doing away with the hinges and using instead a piece of canvas as a hinge the entire width of the door. It goes on with Barge or some other strong qlue and they are easy to replace. That is how they make the tambor doors and it is very efficient.
stagecoachbill
WBCCI #5345
62 Globe Trotter 19'
69 Sovereign 31'
04 E-350 Van 6.0 diesel
stagecoachbill is offline   Reply With Quote
Old 02-03-2006, 08:19 AM   #6
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Hey 65GT!
Your avatar is freakin' me out, man!!!
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 02-03-2006, 11:28 AM   #7
LADYBUG
GT1963's Avatar
Lakefield , ON
Images: 59
You may find that you will need something more ridged - as the angle in which to lift and shuv back onto the top piece and pull forward (hard to expalin) - may get caught and eventually wear the canvas or rip it.
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
Old 02-03-2006, 01:07 PM   #8
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Since mine doesn't have this, can anyone post a picture of this plast hinge thingy? I'm curious whether or not it can be fabricated.
John
AYRSTRM2 is offline   Reply With Quote
Old 02-03-2006, 01:32 PM   #9
LADYBUG
GT1963's Avatar
Lakefield , ON
Images: 59
If we are all talking about the same hinge - this is it.
It is simply stapled into the back of the door. The top piece is only about 3 inches but keeps the door in the track when you lift it and slide it back.
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
Old 02-04-2006, 12:54 AM   #10
Supposititious Blue
65GT's Avatar
Images: 26
Oh yeah, and that's just the head. Try out the full package and see what that does for you. It's my class photo from 8th grade. I'll post the HS pic in a little bit -- stay tuned...
http://www.internationalhero.co.uk/v/viol8r2.jpg
__
Old 02-05-2006, 07:29 PM   #11
Edmond , Oklahoma
hinges
i like that idea of using the canvas. the plastic on my doors seams to run the length of the door and covers maybe a 1/2 inch down the front but i must say that i havent looked to much at the rest of the hinge. i need to find somthing because the door has compleatly broken off.
Old 02-05-2006, 10:02 PM   #12
Shacksman's Avatar
Profile:  1967 22' Safari
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
On my 67 I used brown piano hinges. I left the plastic on the wood and the piano hinge can't be seen. The plastic hinge has to be broken right across to make the piano hinge work. They work just fine but I would like to find the original.
Doug
Shacksman is offline   Reply With Quote
Old 02-06-2006, 10:26 PM   #13
mello mike's Avatar
Phoenix , Arizona
Images: 14
__
Yikes! 65GT, that's even worse!!!
Old 02-07-2006, 01:24 PM   #14
BIGED52's Avatar
MILAN , Illinois
bin door hinges
Wow, My trailer doesn't have a single one of those that I can find....They all appear to be hinged on the bottom edge and the door just swings down and lays on the floor, where you are able to slide the tray out and onto the door, (being careful not to break the plastic latch) located at the top edge of the door! Is this right? Or am I confused? Maybe it is different, (as mine appear factory installed ) on different interior packages? My trailer has the front twins and mid gaucho.... Ed
BIGED52 is offline   Reply With Quote
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 09:28 PM
dinette chair storage bjstewart1 General Interior Topics 16 03-24-2005 10:37 AM
Really a full-size bed mareinmn General Interior Topics 1 09-26-2002 07:47 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
