Old 08-25-2015, 06:41 AM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
U-Shaped Sofa Build
I thought I'd share some pics of the front U-shaped sofa I am in the process of building...
Name:	2015-08-24 16.45.54.jpg
ID:	246294   Click image for larger version
Name:	2015-08-24 16.46.32.jpg
bvcg1 is offline   Reply With Quote
Old 08-25-2015, 06:44 AM   #2
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Like the craftsmanship. Looks great and sturdy.
tsunami is offline   Reply With Quote
Old 08-25-2015, 06:51 AM   #3
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Looks great. I am planning the same type of arrangement in my 1973 Safari. Do you attach to the floor? the walls? or both? Would love to see more detailed plans if you don't mind sharing. I am still in the demo stage - so a bit far from starting this.
Greg
Greg1410 is offline   Reply With Quote
Old 08-25-2015, 07:00 AM   #4
Cardinal283's Avatar
Dallas , Texas
Going to follow a swill be doing this at some point and would like to see your methods and ideas.
Cardinal283 is offline   Reply With Quote
Old 08-25-2015, 07:16 AM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
You do great work! Enjoy!!
Old 08-25-2015, 09:11 AM   #6
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Greg
Boerne? I am in San Antonio, so come take a look. Private message me for my phone number.
I don't have plans. They're in my head, so to speak. To get the sturdiest possible joints I used a Kreg Jig https://www.kregtool.com/store/c13/k...reg-jigreg-k4/
I attached to the floor only so that any flexing of the frame would not affect the sofa, if that makes sense.
Old 08-25-2015, 09:29 AM   #7
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
With you laying the frame on the new floor are you worried about the floor expanding and contracting while the AS is in storage between the winter lows and summer highs? I know it doesn't get that cold in San Antonio but what would happen to the floor between a 0F winter low and a 100F summer high?
I'm planning on converting my 25fb queen to twins. My Classic 25fb bedroom is carpeted and would prefer to pull the carpet and install a vinyl product. Would it be better to install the bed and center nightstand framing before installing the floor? I would want to seal the subfloor under the bed frames so any future water leaks from the windows etc would drain onto a sealed subfloor.
What type of wood are you using? What are the typical dimensions of the frame pieces?
Thanks for sharing.
Kelvin
Old 08-25-2015, 10:24 AM   #8
1976 25' Tradewind
Cottage Grove , Oregon
Looks great, I to would be interested in building this type of sofa/eating area/bed. More details would be great. Thanks
Toolmanbt is offline   Reply With Quote
Old 08-25-2015, 11:05 AM   #9
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Thanks for sharing.
Kelvin
I'm not really worried about it. I expect to be whipping out some caulk after a season or two due to some movement, but I don't expect the sofa to release from the floor. The material used for the frame is select 2x2's (actually1.5 x1.5) pine, so since the subfloor is pine they should move at a similar rate...un-scientific, I know, but it helps me sleep at night. The only other option would be to free the sofa from the floor and leave it 'loose' and maybe use hardware to latch it in place to prevent movement during travel. That actually isn't a bad idea, now that I think about it...
Personally, I would install the floor under the bed space. I agree that it would help seal the subfloor and any water that penetrates would most likely evaporate before it would penetrate to the subfloor. If you are going to use skirting that would prevent air movement in that space, maybe install some vents in the skirting to facilitate air movement and evaporation of any water that penetrates?
Old 08-25-2015, 11:43 AM   #10
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
To allow the vinyl floor to shrink and swell with the seasons, use washers between the couch frame and subfloor. Cut a circular hole in the vinyl that is larger in diameter (1/16"+ clearance) than the washers which will bear the weight of the couch. The height of the washer(s) merely needs to be slightly higher (a few thousandths) than the vinyl thickness. You can cinch down the screws, leaving the vinyl without compression. The washers don't need to be very wide; about 5/8ths of the frame base width or less.
SeeMore is offline   Reply With Quote
Old 08-25-2015, 10:33 PM   #11
laducky's Avatar
1978 28' Ambassador
Pacifica , California
Sweet! This is exactly what I was looking for to model mine after. I have no experience building cabinetry/furniture but this seems doable since it breaks it into box shapes. Please keep posting as you progress! Thanks
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
Old 08-27-2015, 08:04 AM   #12
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Finished the table top cut-out. The design allows for the table pedestal to be removed so that the table top can drop in place to make a bed. After further consideration, because the table top is so large (27" x 44"), I've decided to cut the table top on the left and right and fasten heavy-duty piano hinges so that it can fold in on itself on top. This will allow me to fold and store the table top in the space under the seating. The piano hinges, fastened from underneath (of course), will not travel the whole width of the table. They will stop about 4 inches from the edge so that I can install heavy-duty barrel bolts so the table does not collapse in on itself in either the pedestal configuration or the bed configuration. I will post pics when that is accomplished.
Also, there will be a 3/4 inch plywood layer added underneath (that will stop just short of the bench cleats around the perimeter) for added support
Name:	2015-08-27 08.07.20.jpg
ID:	246462   Click image for larger version
Name:	2015-08-27 08.14.12.jpg
Old 08-27-2015, 03:59 PM   #13
1976 25' Tradewind
So why did you use pine for your sub-floor and dinette, weight factor or ? .
Just trying to learn something new. Thanks
Old 08-27-2015, 05:54 PM   #14
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Regarding the subfloor, Airstream used the pine plywood. As far as the tabletop goes, it's 2 layers of 3/4 cabinet grade high density plywood that will be laminated with Formica. I didn't see the need for an expensive hardwood. The seating structure is select pine for the same reason, except that all exposed surfaces will be painted. Keep in mind that I will have upholstered cushions on the seating surface, with throw-pillows for back support
Sofa cover for jack knife sofa k9jackie Sprinter and B-van Forum 0 05-28-2015 05:30 PM
Does anyone think the L shaped sofa is comfortable? Ntex Buyer Guidelines 16 11-27-2014 10:50 PM
wanted: tee shaped plastic beading cindy General Interior Topics 3 05-02-2003 01:34 PM
Twinkie shaped Motorhomes Silvertwinkie General Motorhome Topics 12 03-06-2003 11:20 PM
Vintage Oval Shaped LP Tank Cover smily LP Gas, Piping, Tanks & Regulators 3 12-20-2002 04:52 PM
