Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-13-2008, 11:20 AM   #1
GA Airstreamer Air_005
ALANSD's Avatar
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Trimming laminated cabinets
My Excella has had the cabinetry replaced with very nice laminated ones. The pantry is especially nice and extra large.
I am wanting to know how to shorten the doors on the pantry so I can add a thicker flooring ( it is quite flush now) without messing up the door. Using a laminate blade, masking tape etc...will that do it?
It has a stick down tile now, and I want to do laminate.
Also I have a tv cabinet with a stereo mounted in it. It was made as a single box wiht no doors. I would like to cut a door in it.. so same question. What is a good way to cut into a mounted cabinet face?
Rallys twice a year..Lots of fun, food, and aluminum.
http://airstreampassion.blogspot.com/
My Music Ministry Site:
HTTP://ALANDAVIDSONGS.COM
Old 05-13-2008, 11:48 AM   #2
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
If you have a high speed router with a guard that will work the best! It will trim the length and not chip up the laminate.
If you do not you could use a saw, but I would only use one with very fine teeth at a high speed!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Old 05-13-2008, 11:52 AM   #3
Profile:  2002 19' Bambi
Lafayette , California
Masking tape and the right saw blade are key. Particular care is necessary with edge banding, if it is present. For cutting the bottom off of laminated doors , I happen to use a very fine cut, new blade on a hand jigsaw and cut from the outside towards the center of the door on any edge banding. As long as you only cut the bottom off, you will not need to replace any edge banding, but be sure to smooth off the face laminate to avoid its catching on something later.
Tim A. is online now   Reply With Quote
Old 05-13-2008, 12:41 PM   #4
craftsman's Avatar
Profile:  2007 25' Classic
Bath , North Carolina
The problem with using a jigsaw on laminate is, the blade moves both up and down. On the up stroke it's pulling on the edge of the laminate and tends to create little micro chips in the cut edge. If you use a jigsaw ,tape the laminate first with masking tape and draw your cut line onthe tape. I find ,using a Skill-saw and cutting from the back produces the cleanest edge because the teeth are rotating into the cut and not out of it. Using a table saw there is a small 4" blade that protrudes above the table about 1/16" of an inch rotating in the opposite direction of the main blade that scores the laminate before the cut, that creates a near perfect cut.
Jack Palmer
craftsman is offline   Reply With Quote
Old 05-13-2008, 12:51 PM   #5
ALANSD's Avatar
Thanks for that. i am a little limited in the pwer tool department, but do have a jig saw with a laminate blade that works well. Also I wondered about using a rotary tool with a cut off wheel.
I will remove the doors to cut them,. but the "box" cabinet is attached to the side of the refridgerator cabinet surround and may be more of a challenge.
Old 05-13-2008, 03:22 PM   #6
craftsman's Avatar
Use some 1"x2" as straight edges for a guide for cutting the opening in the cabinet . A couple of drops of hot melt glue to attach them and then knock them off after. Just light pressure against the guide with the rotary tool or jig saw and you should get a clean opening.
Jack Palmer
Old 05-13-2008, 04:23 PM   #7
vhord's Avatar
Profile:  1970 27' Overlander
Crosby , Texas
Images: 96
Alansd, you are right, they do make special jig saws blades for laminates that cut on the down stroke (reverse tooth) instead of the up stroke like regular blades. One that Vermont American makes is SKU #30018. Taping would probably still be advisable.
Vernon
1970 27' Overlander Restoration ("The Silver Belly", aka The SB)
Photo gallery
AIR #26858
Nothing is fact until it is etched in stone....and even then sometimes it isn't.
vhord is offline   Reply With Quote
Old 05-13-2008, 05:48 PM   #8
ALANSD's Avatar
I have used that method to cut laminate flooring. It worked well.
Old 05-13-2008, 05:51 PM   #9
ALANSD's Avatar
thats a new one for me, thanks for that idea. Would you suggest drillng a small hole to start the saw in?
Can I see your cabinets?? ckelly617 All Argosy Trailers 11 03-18-2008 08:45 AM
Anyone Built New Cabinets kneal Cabinets, Counter Tops & Furnishings 27 01-31-2007 01:03 PM
how to get like new, the fake-wood laminated panels ? brunoffrance Upholstery, Blinds, Walls & Interior Finishes 9 05-21-2006 07:25 AM
Laminated aluminum ALANSD General Interior Topics 18 01-28-2005 03:07 PM
help with refinishing cabinets yaakman Cabinets, Counter Tops & Furnishings 9 09-06-2002 06:01 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
