Old 03-25-2019, 01:16 PM   #1
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Send a message via Skype™ to Zeppelinium
Tilting drawer
In my remodel of my '73 Safari kitchen, I had an odd space under the oven. The open area inboard of the water heater was about 10" deep, so I made a tilt-out drawer for the space. If you plan the cross section just right, you can either lift up and remove the whole drawer, or you can tilt it out and it will catch at about 60 degrees.
Here's the drawer closed and open.
The trapezoidal cross section allows the drawer to swing open and catch on the cabinet rail above.
The key to making this work is a 3/4 x 3/4" bar under the drawer box. The cabinet rail below the drawer is routed to 1/2" radius, as well as the bar. I allowed about 1/16" space between the bar and the drawer front to promote an easy swing action.
Name:	tilt hinge.jpg
Zep@Charmedquark.net
Zeppelinium is offline   Reply With Quote
Old 03-25-2019, 01:30 PM   #2
2007 22' International CCD
Tilting drawer
Clever use of space, and an even more clever drawer design. Looks like the glove box on my truck, sorta.
The hingeless hinge cleat is really clever, and I bet the whole thing will stay in place even better when it has a load in it!
Very slick!
Old 03-25-2019, 05:34 PM   #3
1973 23' Safari
1977 23' Safari
I used this design on my Overlander about 10 years ago and it always remained in place when towing. And reasonably easy to use, too.
I like to use every cubic inch I can.
Zep
Old 03-30-2019, 08:21 PM   #4
1972 27' Overlander
Columbus , Ohio
Hi, in the installation instructions of the oven I am about to put in it said the bottom of the oven should be supported. Are you supporting it on the water heater or are you just going to let it hang from the countertop?
action95 is offline   Reply With Quote
Old 03-30-2019, 11:40 PM   #5
1973 23' Safari
1977 23' Safari
I have let it hang for years. No problem. However, I allowed (I thought) 1/16th space for the rail below the front of the oven, but it's actually resting on the rail. Hard to tell how much support the rail is providing, but I don't think I have supported the bottom of the oven in any of my three remodels.
Zep
Old 03-31-2019, 08:09 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hi: I sure like the tilt out storage space. Very good idea for gaining easy access storage room.
My 75 Overlander has a tilt out radio holder on the street side of the gaucho. I thought that was a nifty idea too. It is only about 5" high and 10" wide. It is made from aluminum.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
dbj216 is offline   Reply With Quote
tilting rear end of '68 GT mimibeth Axles 4 09-10-2006 06:53 PM
Outside rear storage drawer Geri Exterior Storage Compartments & Access Doors 0 07-19-2003 07:57 AM
tilting floor bdbluegrass Repairing/Replacing Floor &/or Frame 9 07-01-2003 05:19 AM
Drawer slides 1988 345 howardann Airstream Motorhome Forums 10 03-15-2003 09:14 AM
Drawer latches eracism Cabinets, Counter Tops & Furnishings 1 11-04-2002 09:37 PM
