11-06-2010, 09:26 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Tile Backsplash?
We are replacing all the cabinetry in our "78" Ambassador. I am ready to put down the new retro formica countertop on the galley and was wondering if anyone has installed a tile backsplash. The surface area will be minimal so I am not concerned with weight. I have also heard there is a flexible grouting material that will stand up to the flexing of an Airstream. Has anyone done this and if so, do you have pictures and how has it held up? Thoughts? Thanks!
TAC PA-5
WBCCI 4871
11-07-2010, 05:47 AM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Bob,
We have a small tile backsplash in the kitchen. I used the 1 inch glass tiles--three high so only a 3 inch backsplash which is more than adequate (and fits nicely under the window without cutting any tiles). They are three different colors arranged randomly and compliment the decor of the walls and the countertop.
They come in 12 x 12 sheets so I simply used acrylic latex caulk to attach them to the wall, let that cure for a few days and then used a black silicone caulk (our countertops are nearly black) to fill in the grout joints. The caulk is flexible enough to tolerate the movement--I was a bit concerned about using any other grouting material. The 'grouting' with silicone caulk is a bit messy but cleans up with mineral spirits.
Don't have any pictures but if this information is helpful to you I will try to post some.
Good luck,
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
11-07-2010, 07:42 AM
1987 23' Sovereign
Tucson
Glad you asked the question, I've been thinking of doing the same thing. Any pictures?
Judy
other half of CampAz
Member 4CU
11-07-2010, 07:50 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Bill...any chance you could post a picture? I assume the acrylic latex caulk was an adhesive caulk? Do you think there is any need to use a thin backer board and then fix that to the sidewall? Sounds like you went directly onto the wall itself. How has this held up for you? We're thinking about using the 1" tiles also...Thanks!
11-07-2010, 10:09 AM
1972 31' Sovereign
Lexington
I'm looking at tin ceiling tiles to use as a backsplash. I need to wait for cabinets (might be a year or so) before I can figure out if it will work. Size will be a factor. There was an article in This Old House Mag. this past month with lots of links to various tin ceiling tile manufacturors. Got me thinking about that center strip in the ceiling too..... Hafta wait for spring for that stuff.
11-08-2010, 05:43 AM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Bob,
Attached is a picture of our little backsplash. Yes, the caulk was adhesive. I don't see any need in putting any sort of backerboard on since I am relying on the flexibility of the caulk (both holding the tiles on and the 'grout') and a backerboard would defeat that purpose. Backerboard also creates a situation that moves the tiles out from the wall the thickness of the backer which would have to be filled with something at the top.
This tile has been in our trailer for a couple of years now with no change--it has held up well.
All the best,
Bill
Bill Cantrell
AIR 24338
TAC SC-1
11-08-2010, 06:05 AM
1977 Argosy 24
Milltown
, Wisconsin
Bill that looks really nice, did you use 100% black silicone for the grout, or was that latex calk also, like you used to stick the tiles to the walls?
11-08-2010, 01:54 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Bill...nice job! Did you order your tiles online or go to one of the big box stores...or other?
11-08-2010, 05:52 PM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Ventport,
Yes, used 100% silicone for the grout. Could have and would have preferred to use a black latex but couldn't find any at the time. Would have been easier to work with. Some painters tape applied around the edges of the tile on the wall and countertop contained the mess to the degree possible.
Bob,
Got the glass tiles from Lowe's. They come in 12 x 12 sheets with a mesh backer which I just cut down into 4 strips. I think I bought two sheets for less than $20.
I would only suggest that if you use caulk as the tile adhesive to spread it out evenly on the wall with a putty knife or similar tool, and then press the tile into it (the mesh grabs and holds well). If you leave the caulk in bead form, a good bit will ooze into the grout joints. This is only a real problem if you are using different adhesive and grout caulks.
I also noticed in the my picture that it appears there is a bow in the corner but this is some illusion of the photograph--there is no bow, it is all straight.
Looking forward to pictures of your completed project.
Bill Cantrell
AIR 24338
TAC SC-1
11-30-2010, 08:15 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Bill...just ordered our tile from Lowes. We went with similar glass tiles but in a lighter color pattern to match our interior. Will post pictures once they are on. Is the adhesive caulk subject to issues with cold weather. Probably will fire up the furnace and wait until the interior warms up.
TAC PA-5
WBCCI - 4871
12-01-2010, 05:30 AM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Bob,
I would have the interior 50 degrees or higher while you are working with it and until the caulk cures. Once it cures out you don't have to worry about temperature. I would also keep the caulk inside the house to keep it warm until you use it--cold caulk is hard to work with.
Can't wait to see your pictures of the completed project. Good luck!!
Bill Cantrell
AIR 24338
TAC SC-1
12-01-2010, 11:46 AM
1995 31' Land Yacht
Clovis
Bill,
What did you use for your counter top?
Myrna
TAC: CA-3
12-01-2010, 12:38 PM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Myrna,
It is just a really dark formica. It is basically black with faint speckles in it.
Has held up well.
Bill
Bill Cantrell
AIR 24338
TAC SC-1
09-05-2011, 08:46 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Well we have the tile and are in the process of putting in on. Had to put in the aluminum panel first. Will follow Bill's suggestion with the adhesive caulk and latex grout. Keep your fingers crossed. Here is what we have so far...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
ceramic tile
robertel |
Floor Finishes |
2 |
08-03-2010 07:55 AM |
Tough As Tile
Lumatic |
Upholstery, Blinds, Walls & Interior Finishes |
5 |
12-07-2009 08:56 PM |
Kitchen counter backsplash ideas
Safari Tim |
Cabinets, Counter Tops & Furnishings |
13 |
06-08-2005 03:50 PM |
Tile and Wood
dbtolman |
General Interior Topics |
2 |
09-09-2004 04:21 PM |
tile under toilet
Holzarbeiter |
Sinks, Showers & Toilets |
11 |
04-03-2004 09:17 AM |
