Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-05-2008, 02:38 PM   #1
Mini Rivet
Profile:  1975 25' Tradewind
Holland , Michigan
The other kind of bunk bed
I would like to build bunk beds for my Tradewind and can find loads of info here but only on the canvas bunk and the wood one that flips up and attaches to the ceiling when stored.
I am looking for info on the one that folds in half and down and makes a backrest for the bottom bunk. In my service manual it looks like its made out of angle with a 3/8" plywood base and hangs from straps as oppose to the cables.
In other threads Andy at Inland has said he has the ceiling brackets and hinges, I would like to find the wall bracket and other hardware to build two of these or can someone provide pictures and measurements so I could fabricate my own.
Your help in this is grealty appreciated.
Here is a page from the 1975 manual, I got it from this thread:
factory Bunk questions
Here is the only picture or referance on this forum I could find for what I am looking for.
From this thread: Any one know where to find pictures of the bunk bed attachments
Two photos from vintageairstream.com
1975Tradewind3
Bruce,
My blog for the 1975 Tradewind restoration
Parts needed: Left Wing Window Dual Pane, Fan roof vent or whole vent assembly, Reese old style dual cam sway control, one 30# aluminum propane tank
bmklawt is offline   Reply With Quote
Old 12-18-2008, 09:38 AM   #2
Profile:  Currently Looking...
Divide , Colorado
Looking at the diagram I think it would be failrly easy to fabricate the bunks on your own. If I was doing it I'd use aluminum angle iron to save weight (can be a pain to weld though). If you can get the bunk hinges then you can probably find a hinge at your local home depot for the back wall. Personaly, I'd forego the ceiling straps and build two support feet, one for each outside corner. It would give you more strength in the bunk and if you made a way to attach it to the lower bunk you could probalby sleep an adult up there if you really wanted to. Neat setup, especialy for a family since AS isn't really good at family friendly floor plans.
gloriavoxdei is offline   Reply With Quote
Bunk Bed pmacdavid All Argosy Trailers 7 10-09-2008 10:44 AM
Folding bunk bed azfiredog300 Cabinets, Counter Tops & Furnishings 12 12-24-2007 01:27 PM
bunk bed tandemfish General Motorhome Topics 3 10-11-2004 08:29 AM
Bunk bed aviontt Cabinets, Counter Tops & Furnishings 6 09-02-2003 03:41 PM
Bunk bed or B.B.parts aviontt Parts Archive 0 05-11-2003 03:21 PM
