Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 03-25-2008, 12:56 PM   #1
Profile:  1978 31' Sovereign
Merlin , Oregon
template for curved walls?
Hello,
I gutted my 1974 31' sovereign all the way to the bathroom closets. (ignore the 78) I called a cabinet maker for a quote.... a very large quote. He mentioned that it would be easier for him to set the cabinets flush with the curved walls if I had some kind of template. Or maybe a track that was once flush with the wall to use as a reference.... However, I don't have a track that I want to give him.
My question is... Is there some kind of diagram that I can sketch out on graph paper or something? I'm guessing most airstreams in the 70's had the same wall structure, as far as height and curvature. any ideas?
-spanks
spanky1313 is offline   Reply With Quote
Old 03-25-2008, 01:09 PM   #2
Profile:  1973 25' Tradewind
Romulus , New York
cabinetry
To find the radiis of the contour is not out of a good carpenter's grasp. Did you save a bulkhead? The body is uniform, the contour can be graphed with a plumb story pole with a level standoff from the plumb sidewall. Then finding the "arc" is done with evenly spaced measurements. Lay out the measurements on foamcore or even cardboard and cut the arc. Trial and error to get a good template before transfering to the finish filler piece. Boom Done!
jayray5 is offline   Reply With Quote
Old 03-25-2008, 01:20 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
See http://www.airforums.com/forums/f46/...ead-29308.html and http://www.airforums.com/forums/f36/...pes-29321.html. Does that give clear enough of a picture?
Old 03-25-2008, 01:46 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Through one restoration and in the midst of another, I have found the radius to vary from what appear to be curves that are the same - both vertically & horizontally. My conclusion is there is no "standard template" which is why it is so important to keep original pieces for templates during restoration projects. Each vintage Airstream has it's own unique quirks.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
building bunk beds on curved walls jiffypop General Interior Topics 11 06-14-2007 11:03 PM
Curved window Canstreamer Windows & Screens 0 10-30-2006 04:47 PM
Help --need a '67 floor template pinkflamingoes Repairing/Replacing Floor &/or Frame 17 08-01-2006 03:11 AM
Impromptu Photo Rallies in CA: A planning template myoung The Rally Zone 5 02-20-2006 11:41 AM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 07:28 PM
