Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-18-2007, 02:26 PM   #1
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
Tambour Wood or Fake?
Hi All,
I had a neighbor look inside my airstream and he made the comment that my tambour doors were plastic? He said his were real wood on his Argosy? What are yall's made of? I knew mine weren't solid wood but I believe they are a particle board of some type. All other wood seems to be real. Now I'm self conscious of a cheap look and want to replace tambour with real wood doors.
thanks
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 05-18-2007, 02:33 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
They may be a laminate in a 70 O'lander - do they look like these?
If so, they are laminate...
But who cares what your neighbor thinks...if you like them and they function, right? But if you must change them...oak tambour is readily available from various sources so they could be replaced.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 05-18-2007, 02:44 PM   #3
Houston , Texas
thanks
your right, I like'm and they work fine. . . . to hell with him.
James
____________
1970 Overlander
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 12:35 PM
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 06:31 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
