Old 08-02-2011, 04:40 PM   #1
1978 Argosy 30
1984 31' Sovereign
warwick , Rhode Island
Tambour replacement?
Where can I find a replacement tambour 28" for overhead cabinet. Dark wood. Any ideas?
stgerdonly is offline   Reply With Quote
Old 08-02-2011, 07:02 PM   #2
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Try the woodworking supply places such as Van Dykes or Woodworkers Supply. If you find one, it will likely be oak, unfinished. Any good custom woodworker should be able to make one for you, to your specs. The strips are basically just glued down on a piece canvus or heavy cloth. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 08-02-2011, 08:08 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you just need a replacement tambor in the factory colors, most Airstream dealers can help you. If it's a custom color, there are several places on the 'net. You might even try a window accessory place.
Expansion anchors instead of elevator bolts for shell on floor replacement? timzog Repairing/Replacing Floor &/or Frame 4 12-12-2011 05:43 PM
Panel Replacement Bert Gildart Ribs, Skins & Rivets 3 08-02-2011 10:55 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Want to replace kitchen tambour doors Gkiesel Cabinets, Counter Tops & Furnishings 0 03-13-2011 06:33 PM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
