Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-25-2006, 07:29 PM   #1
Profile:  1973 31' Sovereign
Park City , Utah
Tambour help please.
I am seeking suggestions on repairing the "roll-up" storage "covering" under the beds and the sink area. The prior owner tried clear silicone on the fractured seam edges, but it didn't work and made a mess. I tried duct tape and mylar, but it would not attach to the paper backing.
Merry Christmas......
Mcstreamy is offline   Reply With Quote
Old 12-25-2006, 07:48 PM   #2
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Mcstreamy,
Welcome to the forums...the stuff you are looking for is called "tambour" run a board search and you will get several sources for replacement. I have never had much luck repairing it, replacing it seems to be the best way to go. Most of mine are still in pretty good condition and the couple that need replacing are going to be done away with as part of the remodel.
Aaron
WBCCI #2449 AIR #2495
Old 12-25-2006, 08:43 PM   #3
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 65
Airstream Registry
HI and welcome to the forums - you have the coolest user name!
Tambour can be repaired, but it can also be replaced with wood, vinyl and even aluminum. Use the search tool on the upper blue bar and search tambour repair.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is online now   Reply With Quote
Old 12-25-2006, 08:57 PM   #4
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Go to Woodworker's Supply. They have supplies to repair and build tambour doors.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 12-25-2006, 09:07 PM   #5
59 GlobTro's Avatar
Profile:  1959 18' Globetrotter
1975 31' Sovereign
1967 22' Safari
Eaton , Colorado
Tambour door repair
We have a '72 Ambassador with the same paper backed tambour. Ours was nearly completely seperated with only a few of the strips still connected. The first thing I did was to get some off-white, all-cotton denim from the fabric store. Then on the work bench, I cut the remaining pieces apart and cleaned the dust off of everything. The next step was to cut a piece of denim the size of the door minus 3/4" on both sides(so it will still fit into tho tracks). To adhere the tambour strips to the fabric, I used 3M 77 spray adhesive directly on the fabric. Then I laid the strips onto the cloth using a large framing square to keep it all true. The glue dries very fast and was ready for installation within minutes. It worked very nicely. Merry Christmas and good luck!
Will and Lori
Lori & Will
1959 Globetrotter "GlobTro"
1967 Safari "Dusty"
1968 Safari "Cheyenne"
1975 Sovereign "Lovey"
1972 Ambassador "For Sale"
1975 Romany "Parts"
1970 Overlander "Parts"
1968 Ambassador "Larry" (for parts)
59 GlobTro is offline   Reply With Quote
Old 12-26-2006, 08:26 AM   #6
steelbird312's Avatar
Profile:  1989 29' Excella
1956 22' Safari
Crossville , Tennessee
Images: 11
What Will and Lori Said!
There is very little as satisfying as effecting a repair......and it being a good, successful one.
Do it yourself and enjoy the satisfaction.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 12-26-2006, 11:26 AM   #7
Profile:  Corona , California
The paper backed Tambour doors were replaced "in warranty" by Airstream many years ago. They recognized the fact that the paper backing would never last over the short haul, let alone the long haul.
That warranty ended over 30 years ago.
To repair then after silicone has been applied, would be a waste of time.
Tambour material is available from an Airstream dealer, or from other sources as well.
A 31 foot trailer will take two 4 x 8 sheets if you wish to do a full replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 12-26-2006, 01:55 PM   #8
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
59 Glotro is correct. Used the same 'technique' to repair a roll top desk.. Works fine, lasts a long time.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 12-26-2006, 04:19 PM   #9
STREAMTEAM's Avatar
Profile:  1973 23' Safari
Alamosa , Colorado
McStreamy,
Thanks for bringing up this topic. We've got repairs done with duct tape and when it gets hot the tambor comes apart. We need to do about 5 doors and
I think the spray adheasive on denium sounds like the ticket, thanks for the tip GlobTro...Was it diff to get the doors out of the roller brackets??
STREAMTEAM
STREAMTEAM is offline   Reply With Quote
Old 06-07-2007, 06:48 PM   #10
Profile:  1974 31' Sovereign
austin , Texas
I'd like to repair my tambour doors. Based on my research, it sounds like the "right" way to fix broken cabinets is to take the tambour apart first, re-align all the pieces, spray glue, apply canvas backing, and put the cabinets back.
I have an idea for a quick fix and I'm wondering if it's a bad idea. The tambour under the bed has split. I've removed the bed and can see the tambour from the inside. It seems like I should be able to role the tambour down into place, spray adhesive directly on, then place fabric on top, without ever removing the cabinet. I imagine doing the same for the cabinets under the couch. This will save me lots of time getting the tambour out. Has anyone done this?
Thanks.
kween is offline   Reply With Quote
Old 06-07-2007, 06:55 PM   #11
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
Here's my techinique. Some of the tambour I repaired 5 years ago and they still work fine.
1. Reconnect the strips with aluminum tape across the direction of the tambour 6" apart
2.glue a layer of nylon packcloth over the backs with contact cement
get off the road hippy
Lumatic is online now   Reply With Quote
Old 06-07-2007, 06:58 PM   #12
austin , Texas
Did you do this with the tambour in place, or did you remove the cabinets first? Did you remove the original paper-backing?
That sounds like a good technique. I just want to avoid removing the paper and also avoid removing the cabinet for the repair. Thanks!
Old 06-09-2007, 02:55 AM   #13
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 21
Airstream Registry
You Don't Need to Remove the Cabinets...
to replace Tambour. If your Tambour is still in place, simply lift it up and unscrew the plastic mount on one side. After you do this, you should be able to remove the Tambour door along with the plastic mount.
1972 Sovereign Intl (RB)
2003 Ford Excursion (6.0L PSD)
Prodigy/Equal-i-zer/Link 1000 Monitor/Xantrex Freedom 10 Inverter-Charger
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-09-2007, 07:23 AM   #14
Lumatic's Avatar
1967 24' Tradewind
Ditto.
No need to remove the cabinets, or the paper backing. Trim the edges of the paper backing with a utillity knife so they fit flush. If the paper backing has gotten stiff break loose the paper between the slats after the goo has set and cured. The paper backing sucks up the glue like a sponge. You will need several coats. The overhead and under bed tambours are easy. they pop right out. The cabinet tambours are a bit more of a challenge and reguire some dissassembly of the face of the cabinet to get at them.
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 12:36 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 03:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 01:00 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
