Old 06-09-2012, 02:31 PM   #15
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
putting repaired tambour doors back in
After following your advice, we repaired the tambor in the bedroom, but are having a hard time gettin the doors back in now that they are in one piece. Any advice?
sunny75 is offline   Reply With Quote
Old 06-10-2012, 01:09 PM   #16
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Is there a possibility you ran the backing all the way to the edges? If so, I suspect the thickness inside of the slides is too great for good freedom of movement. Were it mine, and that the case, I first would attempt to remove the 1/4 inch or so from each side, clean the glue residue and see if that would correct the situation.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 9 02-18-2016 09:56 PM
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 12:36 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 03:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
