Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-03-2004, 03:01 PM   #1
Profile:  Lake Elmo Mn
Question Tambour door in sink base
I have a 25' 1977 Tradewind with a contoured sink base. The tambour door below the sink binds badly so I need to repair/replace it. I haven’t a clue on how to get the door out. I don't want to disassemble anything unnecessary. Any help on this would be appreciated.
Pathfinder is offline   Reply With Quote
Old 04-03-2004, 04:14 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
I removed the bottom track on mine, as there is an airgap underneath it and above the floor. Had to drill out a few rivets and remove some screws.
My tambour is not contoured, however. Yours might be different.
The tambour receptacle is a metal tube with swirls attached on the top and bottom.
Make sure the transition from the swirls to the tambour track is lined up perfectly, or it will bind worse than before. A bit of silicone lube will do wonders on the tambours.
Uwe
www.area63productions.com
Old 04-19-2004, 06:47 PM   #3
MontanaArgy's Avatar
Profile:  1976 Argosy 20
Helena , Montana
Send a message via AIM to MontanaArgy Send a message via Yahoo to MontanaArgy
On my 76 Argosy all the tambour doors were in good shape but bound up and difficult to use. A shot of real silicon spray in the tracks (both sides of each track) and up into the end roll tracks and they are good as new. Amazing.
MontanaArgy is offline   Reply With Quote
-Wanted- Tambour Track-for Sink Cabinet Navigator Parts Archive 0 02-11-2004 05:27 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 07:06 AM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 07:51 PM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 01:00 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
