Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 01-04-2009, 11:30 AM   #1
Profile:  1973 31' Sovereign
Question Tambour door in rear bath above tub stuck
During my last trip the contents of the cabinet with a tambour door above the tub in a Rear bath 1973 31 ft Airstream shifted and now the tambour door with only open about 1.5 inches. Something has gotten wedged against the area where the door rolls up. I have tried a coat hanger but no luck.
Anyone got any ideas?
AustinAir is offline   Reply With Quote
Old 01-04-2009, 11:51 AM   #2
Commercial Vendor
Profile:  Corona , California
The tambour material curls up in a spiral when you open the door.
Either something is in that spiral, or the shape of the tambour has changed because of dirt and grime.
If worse comes to worse, part of the molding can be taken off, so that the tambour can be removed.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-04-2009, 01:58 PM   #3
Profile:  1999 30' Limited
Richmond Hill , Ontario
Hi - instead of trying to push "up" on the Tambour, try reaching up to the "roll" and rolling it up that way (If you can get your hand in there, that is). This assumes something is not jammed in there (sometimes they just warp). Or try and flatten the tambour on the outside as it rolls up. Another option is to try to lubricate the tracks with a silicone spray. Good Luck - Rob
ALTE797 is offline   Reply With Quote
Old 01-13-2009, 07:32 AM   #4
Still can't get Tambour Open
I have tried everything I know to remove object lodged in my tambour door above bathtub in rear bath model. Andy, you mentioned that I could remove the molding and then remove the tambour. I was wondering about that. The door slides sideways. Do I drill the rivets on the top and bottom pieces where the door slides and remove them and the piece that covers the rear of the cabinet where the tabour rolls up? Thanks for any help, I am fairly new to this and not super handy at repair. Althought a 36yr old unit will make you learn quickly.
Andy Oliver
Old 01-13-2009, 08:31 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I had a 73 Sovereign and had the same problem. In my case it was a combination of the canvas backing fraying and bunching where it rides in the track and catching the aluminum track where the tambour comes out of the storage roll. If wiggling and nudging does not work it loose. Work on lossening the bottom track by drilling out the rivets. When you finally get it out cut off a 3/8 to 1/2" strip off the canvas so there is less thickness to the tambour and it slides easily. Another thing I did was cut the tambour in half so only half loads into the storage track. The tambour always gets stuck going into the storage track. Less going in and the less are your chances it gets stuck.The other half stays in front and you can still get to what you want by sliding it to the left or right.
I did the same think on the large tambour under the kitchen sink.
Pay no attention to the man behind the curtain- WoZ
Lumatic is online now   Reply With Quote
Old 01-13-2009, 12:26 PM   #6
Profile:  1973 27' Overlander
Space Coast , FL
That sounds like a really good solution for mine in the kitchen .... how to you secure the draw/handle from the fwd portion back to the part that will go into the track?
funkill is offline   Reply With Quote
stuck tambour door airbrushgal Cabinets, Counter Tops & Furnishings 27 07-29-2008 09:45 PM
Bath Tub out4trout Sinks, Showers & Toilets 2 01-15-2008 10:30 PM
Bath Tub Stained Really Bad Cleanable? lanajane Sinks, Showers & Toilets 2 04-30-2007 11:36 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 12:15 PM
Wanted-sliding bathroom door-rear bath Rick Alston Parts Archive 0 01-28-2004 04:58 PM
