Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-19-2006, 06:26 AM   #1
26.982 amu
Profile:  1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Tambour alternatives
I'm not angry with my jammed, buckled, ugly galley tambour anymore--I just want it gone. I'm interested in what anyone has done to creatively replace tambour --in other words, what non-tambour solutions have you come up with?
26.982 amu is offline   Reply With Quote
Old 05-19-2006, 06:31 AM   #2
overlander63
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
How about hinged sliding doors? Lift them up and out at the bottom, and slide them back over the top of the cabinet.
(No Longer at Inland RV)
Old 05-19-2006, 09:45 AM   #3
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
sliding by-pass
hi- I had same problem with my '72, decided to go with sliding doors. I made top and bottom tracks by putting 2 saw kerfs in a strip of wood that I then fit and glued into the metal channels, then simply used formica as the doors themselves. I do not plan on keeping loose heavy items in these compartments while traveling, but if you do you might want something thicker and stronger than formica. Just one way to go, simple and light, no hardware. If you wanted a CCD effect you could use that translucent plastic panel used in flourescent light fixtures, with a small light inside the compartment. Overlander 63 has a good idea too, probably many other options if you are creative.PM me if you want more info on my idea- Tim
tphan is offline   Reply With Quote
Old 05-19-2006, 10:17 AM   #4
Frank S
Frank S
Profile:  1973 27' Overlander
peoria , Illinois
Hi Vince Brach--A refinement to "tphan's" sliding by-pass: use extruded plastic double channel. It looks like a squared "W" in profile ( LLl ) is about 5/8" wide and 3/8" high with two tracks about 1/4" wide each. What I saw was in dark brown, and relatively inexpensive, in one of the big box stores, where they have shelving. Use 1/8" hard masonite for the sliders and drill a 1" finger hole in each slider for opening. Have about a 1" over lap at the center of the space. Toward the bottom of the overlap drill about a 1/4" steep angled hole down thru the overlaping sliders into the bottom frame. Into this hole insert a nail when traveling to keep the sliders from vibrating open. I haven't done this yet as most of my tambors still work pretty well, but I'm getting ready to do one sticker.--Frank S
Frank S is offline   Reply With Quote
Old 05-19-2006, 10:35 AM   #5
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I made regular cabinet doors to replace my missing tambour. They worked really well.
Here are some pictures.
http://www.thevap.com/safari/pages/dinette1.htm
http://www.thevap.com/safari/pages/n...20plumbing.htm
http://www.thevap.com/safari/pages/c...%20furnace.htm
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-28-2006, 05:31 PM   #6
Alumin8
Profile:  1973 31' Excella 500
Morristown , Tennessee
I find the tambor slides very attractive and utilitarian. When my old 1975 land yacht had missing panels, I went to a cabinet supply shop, bought stock tambor (it comes in 4x8'sheets) and cut the sizes that I needed, stained and polyurethaned them. The hardest was getting the into the tracks without completely dissasembling the units. I cut a small slot in the top and bottom aluminum tracks in such a way that when the door was completely opened, it just fit the whole slider. I never had a problem with them coming out. It was time consuming but no more than making swing doors. I couldn't take the constant interference of the doors swinging into the small walkway.
I would certainly do it again and may have to in my new 1973 31' Excella.
Joe
Alumin8 is offline   Reply With Quote
Old 07-28-2006, 09:30 PM   #7
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
the po of my trailer took the old tambor and used it with new framing to make regular cabinet doors. Looks pretty good, he just forgot to add good magnetic latches
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 07-28-2006, 10:45 PM   #8
crowbar68
crowbar68's Avatar
Profile:  1975 27' Overlander
fort wayne , Indiana
tambour slides
Joe
is there a way to fix them? mine are in great shape but they don't want to slide open. they close fine. wax or sooap or sanding or cabinet doors?
crowbar68 is offline   Reply With Quote
Old 07-28-2006, 11:27 PM   #9
crowbar68
crowbar68's Avatar
tambour slides
found a recent thread to deal w/ difficult doors it is Anyone have a fix for this ????.
crowbar
Old 07-29-2006, 06:48 AM   #10
Chuck
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Originally Posted by Frank S
Hi Vince Brach--A refinement to "tphan's" sliding by-pass: use extruded plastic double channel. It looks like a squared "W" in profile ( LLl ) is about 5/8" wide and 3/8" high with two tracks about 1/4" wide each. What I saw was in dark brown, and relatively inexpensive, in one of the big box stores, where they have shelving. ...-Frank S
Frank, what do you suppose the intended purpose of this track was? might help locate it in the vast expanses of big-box-hardware-world.
I have something similar. The PO put alluminum track on the outside of all my cabinets, then used that fake panneling stuff for doors. it works, but its really hokey. the track is readily available, too...the profile is more like a cross between the letter E and F. Imagine rotating the letter "F" 90 degrees left; except 2 tracks. or, "E" on it's side, with a stem. that stem part is riveted to the top and bottom of the cabinets, so the tracks are along the outside of the cabinet faces. there might be pics in my photo gallery...
I'd rather have the old tambour, and fix it up. I've collected some pieces that another member was going to toss....need to get more before I can actually do much with it.
Here is an excellent photo essay on how to make the repairs:
http://www.silvertwinkie.com/tambour/
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-29-2006, 10:08 AM   #11
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
We replaced one of the two tambour doors that didn't work in our 78 Argosy. I love this door in the bathroom; however, I haven't decided how to replace that large one under the kitchen sink. Think we may go with a double door type similar to this one. It's only the horizontal ones that we have had trouble with; however, it got old really fast. We just don't open the one in the kitchen any longer.
ID:	23998   Click image for larger version
juel is offline   Reply With Quote
Old 07-29-2006, 06:21 PM   #12
crowbar68
crowbar68's Avatar
silicone/teflon
i went ou t this morning and bought some teflon dry lubricant. it pretty well fixed my tambour door jamming problem. no kidding. a couple good sprays in the tracks and they work great. the only one i have to be delicate w/ is the under sink one, which is the biggest one and only right at the end when almost all folded in. a little more lube and cleaning over a couple seasons and it will probably glide free. the can i got was at lowes for $5, dupont teflon. a few minutes spray and i'm keeping my original tambour doors.
crowbar
Old 07-29-2006, 08:19 PM   #13
Alumin8
Crowbar, (you gotta love that name)
I made new tambour sliders after getting the raw material from a laminate supplier near me. It was real wood and required staining and finishing with polyurethane. While there were no doors in the tracks, I cleaned them and made sure that all of the edges were smooth. Cutting small portals near the collection roll as close to the most open position, I carefully slid the new doors into the track. It took quite a bit of sliding and lubricating to get them smooth. I lubricate with everything that came to mind except for excessive oily materials.
They worked good and looked great. I can't stand the extension into the walkway and the need for secure locks to carry anything while on the road without risk of opening.
Joe
Old 07-29-2006, 10:52 PM   #14
Frank S
Frank S
peoria , Illinois
Hi chuck--The plastic "E" on its side extrusion I mentioned in my 5-19-06 post was rail for sliding doors. I saw it in a big box store in the area where they have finished shelving.--Frank S
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 01:36 PM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 08:51 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
Forums Directory
