Gloria,
Your table may be a 2-piece model, that folds over itself.
If you pull the one end of the spring clip out of the top section, you should be able to flip the section out, lift up on the end by the window, and double the size of the table. If you look on the underside of the table there should be a flip lock that piece undone allows the end to extend out to support this additional tabletop.
If you only have one piece as a table, then a PO took out or had break off the other half.
__________________ Brett G WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome Wise men talk because they have something to say; fools, because they have to say something. -- Plato
