Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
View Poll Results: Table Up or Table Down When Traveling?
Table set up with one side folded on top of the other 15 34.88%
Table set up with both sides open to their fullest 0 0%
Table down, hanging from long hinge and resting along inside of trailer 17 39.53%
Table is a dinette or on pedestal(s) 11 25.58%
Voters: 43. You may not vote on this poll
Prev Previous Post   Next Post Next
Old 02-07-2006, 08:11 PM   #1
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Table Position When Traveling
I have found that the screws started pulling out of the hinges of my folding tabletop. Out of 8 screws, half of them would not tighten because they stripped the wood out. I identified those offenders, shot JB Weld into the holes stripped out and set the hinges back in. I realize that JB Weld might be a little extreme instead of a wood putty but I did not plan on this thing being a problem again.
I never had a problem with my '77 Excella but then I always had the table set up and one side of the table folded on top of the other. On the '86 Sovereign, I have traveled over the last year with the table leg folded and table stored next to the side of the trailer, i.e. down. From now on, the table will have the leg out and the table up.
Has anyone had this problem and what do you do?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 08:40 AM
Pedestal Table eraffety Airstream Motorhome Forums 7 11-08-2002 08:02 AM
New Front Credenza/folding table j54mark Cabinets, Counter Tops & Furnishings 5 11-07-2002 06:32 PM
Running the roof A/C when traveling ... Hayseed Airstream Motorhome Forums 3 07-21-2002 09:16 PM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-19-2002 12:47 AM
