Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-20-2018, 10:05 AM   #1
1969 27' Overlander
Boise , Idaho
Table Pedestal Max Weight Loads
I've built a u-shaped dinette, and plan to add a tabletop that can be dropped to turn dinette into full-sized bed. Was going to use one of those tubular table pedestals. I'm wondering about how much weight one of those can realistically handle.
I want to make a live-edge wood slab table top that would be considerably thicker and heavier than your typical particle-board/formica construction. My table top will be 27"x47" when completed. There are a number of "tricks" I could employ in the construction to reduce weight, just trying to decide how aggressive I need to be. Can one of those pedestals handle a 40 pound table top while driving bumpy roads? Should I use two? Come up with a different solution?
Jamespio is offline   Reply With Quote
Old 07-20-2018, 11:10 AM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Since there are a *lot* of people making various table supports, there really is no single answer. Best approach would be to contact the manufacturer and see what they say.
In the case of the big heavy Corian table in the 2017 Classic, the answer is - yup it does the job. I doubt that top weighs much less than 40 pounds.... That only applies to that specific (power lift) pedestal. It *has* been down a lot of bumpy roads ...
Installation Instructions - Replacing dinette table with floor mounted pedestal table dlykken General Interior Topics 13 03-22-2020 02:16 PM
Telescoping Table Pedestal source? redreefet Cabinets, Counter Tops & Furnishings 2 12-25-2010 11:30 AM
Wanted B-van Pedestal table 2RUSS@ATT.NE Member Introductions 4 09-22-2009 07:54 AM
1986 345 AS MH Pedestal Table Jim Tyrney General Motorhome Topics 0 03-29-2004 08:45 PM
Pedestal Table eraffety Airstream Motorhome Forums 7 11-08-2002 07:02 AM
