Old 05-19-2010, 08:16 PM   #1
P&K
P&K's Avatar
1970 29' Ambassador
Images: 37
Sunken/Unlevel Counter
My wife and I just bought a 1970 29' Ambassador. The kitchen counter is not level. The edge that meets the wall is lower than the inner edge, and it is very obvious against the level line the oven creates. Any advice?
P&K is offline   Reply With Quote
Old 05-19-2010, 08:34 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
That's not as uncommon as you might think. Check where the wall and counter join, and make sure the mounting screws are screwed into the holes in the wall. They have probably come loose, and allowed the backside of the counter to drop. You can raise up the back of the counter again, and reattach it using the screws in the holes, and it would probably be a good idea to add some more screws to reduce the chance of it happening again.
Old 05-19-2010, 09:03 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
It may be, as mine, moisture and time have killed the temper of the wood.
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 08:39 PM
'78 Argosy on Unlevel ground aversenti Axles 3 09-15-2006 10:46 AM
counter edging ALANSD Cabinets, Counter Tops & Furnishings 3 09-03-2006 04:55 PM
Bathroom counter balrgn Cabinets, Counter Tops & Furnishings 7 11-09-2004 08:21 AM
Counter laminate Forrest Cabinets, Counter Tops & Furnishings 1 07-06-2002 07:06 AM
