Old 01-31-2013, 01:20 PM   #1
Stuck tambour door
My 74 Argosy motorhome has one tambor door and of course it gets stuck about after about 3" of travel.
There is no access from behind or from the sides. When pushing up it travels fairly smoothly but then within a very short distance it starts binding and it quickly reaches a point where it won't move at all.
Any suggestions on how to fix the problem without destroying the door?
Thanks!
Old 01-31-2013, 01:25 PM   #2
1981 31' Excella II
New Market , Alabama
Silicone Spray.
Perry
Old 01-31-2013, 01:34 PM   #3
I think I've got a can of that around somewhere. I'll give it a try this evening.
Thanks!
Old 01-31-2013, 01:45 PM   #4
1981 31' Excella II
Look for obstructions in the track. Sometimes there are nails, screws, or rivets that hold the track in that are coming loose. Also look for problems with the scrolls that it coils up in. Lube the scrolls on each side as well.
Perry
Old 01-31-2013, 01:49 PM   #5
Perry, I have no access to the tracks. I can't reach in there, I can't get access from the sides or the top. From what I can see I either get it to start sliding or I tear it out.
I'm hoping the silicone spray will do the job.
Old 01-31-2013, 01:59 PM   #6
1981 31' Excella II
You can spray silicone along each edge and you can usually see the scrolls with the door partially open. There is very little film left behind with that silicone so you can be pretty liberal with it. You could get an inspection mirror and a flashlight to inspect things. It could be something as simple as a shopping bag got wrapped around something.
Perry
Old 01-31-2013, 02:05 PM   #7
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
If the door is bent even the slightest amount it binds...try rolling it by hand in the middle of the door
Protohyp is offline   Reply With Quote
Old 01-31-2013, 02:06 PM   #8
Originally Posted by perryg114 View Post
... You could get an inspection mirror and a flashlight to inspect things. It could be something as simple as a shopping bag got wrapped around something.
Perry
Duh, I just bought an bore scope and keep forgetting that fact! I'll use the scope tonight and see what is lurking up behind the door.
Thanks for jarring my memory
Old 01-31-2013, 02:08 PM   #9
I've tried various angles and positions on the door and after it reaches a certain point it just stops. Any pushing after that and you can feel the door wanting to start buckle.
We'll see what the bore scope shows this evening.
Old 01-31-2013, 02:32 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I had several in my Excella behaving just that way. Silicone spray worked on all of them. I kept thinking, "I can't get to the scroll part, no way this is going to work." It did.
I still haven't learned to ease up on them. I keep slamming them open now.
Vaughan
Old 01-31-2013, 06:00 PM   #11
1981 31' Excella II
Pushing real hard on them can cause them to delaminate.
Perry
Old 02-01-2013, 01:56 PM   #12
Silicone spray did the job! It still wants to bind real easy when opening but at least I can now get access which should allow me to pull the inside cover to look closer at things.
ID:	177880Click image for larger version
ID:	177881Click image for larger version
The cabinet was nice and clean inside which kinda surprised me considering how the rest coach looked.
Thanks for the suggestions!
Old 02-01-2013, 04:18 PM   #13
1981 31' Excella II
Remove that rear trim panel and I bet you can see the scrolls then.
Perry
Old 02-01-2013, 04:24 PM   #14
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Interesting remains of an old clock above the cabinet. Is that original?
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Horizontal Tambour door stuck angellhill All Argosy Trailers 12 09-14-2012 07:54 PM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Moho generater door Smartstream Classic Motorhomes 23 05-16-2011 06:02 PM
Where can I get a tambour door for my '72 overlander? JackP Cabinets, Counter Tops & Furnishings 4 04-13-2011 11:42 AM
