Old 02-02-2013, 06:28 AM   #15
Originally Posted by perryg114 View Post
Remove that rear trim panel and I bet you can see the scrolls then.
Perry
That's what I'm hoping. I'd like to keep the tambor door but if it's worn out or broken I might have to do something different. I'm keeping my fingers crossed that I can clean things up to be good as new.
Old 02-02-2013, 06:32 AM   #16
Originally Posted by adonh View Post
Interesting remains of an old clock above the cabinet. Is that original?
Don
Don, I honestly don't know. Maybe Fred would have a better feel for whether the clock is original to the coach.
I'm not sure what to do about it since some of the numerals are missing. If it was intact I'd leave it. I'll spend some time looking for either the missing numerals or something that can be put in it's place.
Old 02-02-2013, 11:43 AM   #17
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Here's a source for the numerals: Klockit - Inserts & Dials, Numerals.
As far as the works go, I like this one: Seiko High Torque Continuous-Sweep Mini Quartz Movement. It's a little pricy ($13.99 including your choice of a set of hands vs. as low as $3.25 for the plain movements), but the continuous sweep means that the second hand moves smoothly around like an AC powered clock instead of once a second. Most importantly, that means that it doesn't go "clunk!" every second. I've retrofitted this movement into my hand on the wall clock and the quiet is a huge improvement. Well worth the price.
Vaughan
Old 02-02-2013, 06:24 PM   #18
Vaughn, thanks for the links!
They have several dial faces that would be a good replacement for the numbers currently existing and the continuous movement clock is definitely the only way to go.
Thanks!
Horizontal Tambour door stuck angellhill All Argosy Trailers 12 09-14-2012 07:54 PM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Moho generater door Smartstream Classic Motorhomes 23 05-16-2011 06:02 PM
Where can I get a tambour door for my '72 overlander? JackP Cabinets, Counter Tops & Furnishings 4 04-13-2011 11:42 AM
