Old 04-25-2015, 02:27 PM   #1
kellykellyi's Avatar
1952 15' Cruisette
1967 20' Globetrotter
2010 19' International
La Cañada Flintridge , California
Stripping paint from interior panels
I have looked around here but with no luck. Anyone have tips on stripping 63 years worth of paint from the original aluminum interior panels of a '52? I would love to have the interior of my Cruisette be polished aluminum.
kellykellyi is offline   Reply With Quote
Old 04-25-2015, 07:52 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I think if it was my trailer and I wanted the inside polished, I would highly consider using new aluminum, especially if there are multiple coats of paint.
Aircraft Remover by KleenStrip will get MOST paint off. Multiple coats may require multiple applications.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-24-2015, 10:39 AM   #3
Abstractmom
Abstractmom's Avatar
1959 24' Tradewind
Cedar Park , Texas
Hi there, I've been working on my '59 Tradewind's cabinets and woodwork and have been using Citristrip. I've found it's taking the paint off of the aluminum too when I slop some on where the woodwork meets the walls or ceiling. You might give it a try. It's not as toxic as most chemical based strippers. Good luck! Let us know if it works for you!
Citristrip 1/2-gal. Safer Paint and Varnish Stripping Gel-HCG73803T - The Home Depot
Abstractmom is offline   Reply With Quote
stripping the interior panels nevisstudio Upholstery, Blinds, Walls & Interior Finishes 18 08-21-2015 09:07 PM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Pictures of aluminum interior after paint stripping? 59er Upholstery, Blinds, Walls & Interior Finishes 25 03-18-2011 10:53 PM
stripping paint from original vinyl interior walls Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-10-2008 05:37 PM
permanent decal & paint stripping 0557 Our Community 1 02-19-2004 05:44 AM
