Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 01-15-2006, 10:45 PM   #1
mjmcwhorte
Profile:
Red face To strip or not to strip. That is the question.
We are restoring a 1955 Sovereign whose birch interior is intact. The finish is still reasonable good, but it is somewhat dull and lifeless. I have seen photos of other Fifties models that have a deep, glossy finish that is beautiful, but I don't know if it's original or refinished. Can someone advise me on this? What are the best products either to restore/renew the existing finish or to stip and refinish the birch?
Thanks to all.
Marian
mjmcwhorte is offline   Reply With Quote
Old 01-16-2006, 07:25 AM   #2
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Restoring the finish to cabinets
It depends, of course, on how mistreated the cabinets are. Something as simple as a lemon oil furniture polish may do. We used up two bottles in doing three coats on our '63. If you want higher gloss, you might use a Danish oil refinishing product from Formsby. They also have a more agressive Refinishing formula. If you want to seal the surfaces from all moisture and give a high gloss, you might use a water based urethane varnish. If you want to just protect a very wet prone area, a solvent based varnish may be your answer. To keep the unit as pure as possible, limit yourself to the soak in oils. The finished product looks nice.
Old 01-16-2006, 09:10 AM   #3
startrekker2001
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
Marian,
You shouldn't have to strip your trailer, it didn't have clearcoat in '55. That's a big plus. If you want to polish your trailer be advised it is a lot of work initially and annually to keep the finish looking good. It is a lifetime commitment... and worth every second spent on it.
Go to www.perfectpolish.com for all the information you will ever need. Also Shirley Manning has an outstanding website at http://globetrotter64.home.att.net/ They give an in-depth blow by blow on how to polish a trailer.
You can get there by clicking on the above link or on the perfectpolish home page click on Misc info then on Airstream Polishing Project.
I polished my '78 31' Excella. You can see it on my photos on this website. Just click on my username.
Good luck.
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
Question about a buying decision! escapeez Our Community 7 08-15-2002 03:29 AM
Tire sizing question caadoptees Tires 5 07-02-2002 11:19 PM
test
