Old 12-10-2018, 03:51 PM   #1
Whistler , British Columbia
Stick built/frame cabinets
Hi there,
I have searched this forum to try and find some how-tos on those that have built their cabinets using the stick frame method and have not turned up anything. I have found plenty of people who have claimed to have done it or have posted a pic here or there. Any chance someone may have some links to a build?
Best!
TylerG is offline   Reply With Quote
Old 12-10-2018, 06:09 PM   #2
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
google " site built cabinet "
ALUMINUMINUM is offline   Reply With Quote
Old 12-11-2018, 10:54 AM   #3
I did that and it looks like it just means cabs that have been built on-site. Not specific to the stick built method. Is there an industry term for stick built?
Old 12-11-2018, 12:29 PM   #4
2002 19' Bambi
Lafayette , California
Here is a nice discussion about stick-built cabinets: https://sawmillcreek.org/showthread....t-Construction. Here's another: http://forums.finewoodworking.com/fi...tchen-cabinets.
You might notice that this was a method used by skilled carpenters to build in place. It would save weight in an Airstream, but, as with any cabinet work in one of our trailers, the curved walls can present quite a challenge.
Tim
Tim A. is offline   Reply With Quote
Old 12-11-2018, 08:26 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Accuracy is paramount for cabinet makers and their resulting cabinets. I would suggest this is the reason for the methods used. A small error when translated to a 3D surface 3-4' away would cause the cabinet to be difficult to use.
I would stick with the commonly used methods and downsize the material thickness if there is a need to reduce weight. I was able to load a 24X96" cabinet through the AS door.
sgschwend is offline   Reply With Quote
Old 12-11-2018, 11:37 PM   #6
Pygmypoacher's Avatar
Black Diamond , Washington
Originally Posted by TylerG View Post
Hi there,
Best!
I have pictures of how I built my interior. I only screwed into the wall twice - overhead cabinets and bathroom wall. Otherwise mounting to floor was sufficient since the entire interior is wrapped in handmade furniture of some sort. I used 1x2, 2x2 select pine and 3/4 ply for everything structural. I built mine based on other people's pictures I liked and copied thier designs - at least how I viewed them. Click image for larger version
ID:	329527Click image for larger version
ID:	329528Click image for larger version
ID:	329529Click image for larger version
ID:	329530Click image for larger version
ID:	329531Click image for larger version
Pygmypoacher is offline   Reply With Quote
Old 12-11-2018, 11:40 PM   #7
Link to more of my renovation
https://r.tapatalk.com/shareLink?url...6&share_type=t
Wrapping my year long renovation
Old 12-12-2018, 08:04 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Buy yourself a Kreg Tool.
I have been around since the era of dowels, then biscuits for joinery.
The Kreg Tool is by far the best method I have used.
IMHO
TG Twinkie is online now   Reply With Quote
Old 12-12-2018, 08:47 AM   #9
NO HUMBLE OPINION
Site, stick, in-place, face-frame… Gables or carcass, whether it's vernacular, dialect, colloquial… I don't know. SE Michigan is “site”, what California, Texas, Colorado, Florida calls it could be different.
Airstream builds modules off-site and brings them in through the front door. You'll probably get a better result asking a cabinetmaking forum than Airforum, where it's more about F 250 diesels dominating mountain passes.
You can rivet a ledger onto the wall, and build it out however you like using dowels, pocket screws(Kreg), dominoes, biscuits, mortise, tenon, cleats, brackets, box-joins, dovetails, pegs…
Many have scratch-built fine cabinetry in Airstreams. I doubt that any two are the same. There isn't a single answer.
My cabinets don't follow any particular rule of construction. I modeled them after an old Stickley desk I admired. I have a knee-hole rather than a toe-kick under the sink. I don't know if it's stick-built… I did build them off a ledger, on-site.
Have you asked a cabinet-making forum?
ID:	329541   Click image for larger version
Old 12-12-2018, 09:01 AM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Pygmypoacher, Very nice work. That is the same construction method I used to convert our rear queen bed to twin beds. Much lighter and more storage space.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 12-12-2018, 08:31 PM   #11
I have pictures of how I built my interior. I only screwed into the wall twice - overhead cabinets and bathroom wall. Otherwise mounting to floor was sufficient since the entire interior is wrapped in handmade furniture of some sort. I used 1x2, 2x2 select pine and 3/4 ply for everything structural. I built mine based on other people's pictures I liked and copied thier designs - at least how I viewed them. Attachment 329527Attachment 329528Attachment 329529Attachment 329530Attachment 329531Attachment 329532
Wow, that is so damn sexy! I need to pick your brain a bit on that fireplace install.
Old 12-13-2018, 05:55 AM   #12
Sure, hit me up on my "Wrapping..." thread.
How the '50s and '60s wood cabinets are built Tony S Cabinets, Counter Tops & Furnishings 22 09-30-2013 11:18 PM
Anyone Built New Cabinets kneal Cabinets, Counter Tops & Furnishings 41 11-21-2011 06:23 PM
Dip Stick Bill Resseau Mechanics Corner - Engines, Transmission & More... 26 11-09-2010 05:08 PM
Should cabinets be built to flex? adwriter73 Cabinets, Counter Tops & Furnishings 5 08-20-2010 11:19 AM
Dometic dip stick? Stinky Refrigerators 2 11-03-2003 08:22 PM
