Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 08-07-2006, 09:41 AM   #1
surferstyler's Avatar
Profile:  1972 27' Overlander
San Juan Capistrano , California
Steel looking laminate Counter Tops?
Good morning everyone. We're just getting to the counter tops in our Remodel of our '72 Overlander and have noticed a Formica Steel looking laminate. Also there are a few other brands we've seen out there. Has anyone used these steel looking laminate? Any thoughts or suggestions on the wear & tear of them?
Ron
surferstyler is offline   Reply With Quote
Old 08-07-2006, 10:28 AM   #2
Profile:  canton , tx
Hi Ron. I'm considering the same style of laminate. I really like the look. It will go with the alum mini blinds we installed. As far as the wear and tear, I'm sure the laminate will hold up very well. My 79 MH has the original laiminate and it is in great condition after 25 plus years. Good luck with your project. joe
rvlover is offline   Reply With Quote
Old 08-07-2006, 12:06 PM   #3
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Brand? Which Big Box?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-07-2006, 01:02 PM   #4
Thanks for your reply. Now that I've done more research, there appear to be several more steel looking formica's out there to play with. If anyone has anymore insight into these, please advise.
Ron
Old 08-07-2006, 02:57 PM   #5
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Ron, when we were redoing our kitchen recently, adding stainless appliances, I was stumped for the back splash area around the room. We had used tile elsewhere and I didn't want a repeat of that. During one of my daily (!) trips to Lowes or HD during this time, I noticed masonite paneling with a stainless look in 3" tile design. We used this and everyone who has come by has enthused about the steel on our walls to which we smile, knowing it's just a look alike. This may be over the top for your look, but in addition to your stainless-look counters, you might consider the masonite paneling in the steel look for some wall area. One of my daughters even cut a piece to install on the front of the dishwasher which also looks great. Good luck in deciding on your counters. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 08-07-2006, 03:04 PM   #6
I'll shoot over to HD this afternoon and take a look. Austin Hardwoods, a local supplier has a bunch of these different samples, but they're about 2" x 3" and hard to really get a grip on what a big piece will look like. Thanks for the response, I'm glad to hear your kitchen looks great!
Ron
Old 08-07-2006, 05:32 PM   #7
Profile:  1973 31' Excella 500
Morristown , Tennessee
You may want to look at this site. Interesting, but not a replacement for the real thing.
www.alsacorp.com/
Joe
Alumin8 is offline   Reply With Quote
Old 08-07-2006, 07:36 PM   #8
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Also
WWW.CHEMETALCO.COM
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-07-2006, 08:30 PM   #9
Wow, really cool links. Thanks, I think we may be on the right track here.
Thanks for your help!
Ron
Old 08-08-2006, 01:22 PM   #10
Profile:  2002 19' Bambi
Lafayette , California
With metallic Formica-type laminates, you should check the manufacturer's specs to determine if the material is suited for "horizontal" application. Horizontal is, of course, a countertop. Countertops need to be durable. You do not want to have your new installation look worn only a short time after you have finished it.
If the laminate is not suited for a countertop, you might consider using a sturdy gauge (20-22) of stainless steel glued to a solid plywood backing. The contact cement used for laminate is adequate as long as the stainless-steel surface being glued is thoroughly degreased. The plywood needs to be a void-free type such as "baltic birch". Cutting stainless-steel sheet to size (including sink and stove openings) can be challenging, but a sheetmetal shop can do that for you.
Tim A. is offline   Reply With Quote
Old 08-08-2006, 01:30 PM   #11
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
formica
You willfind that the metal look is not for counter tops, as it scratch's.
Formica makes a silver which I used and it match's the blind's perfectly.
Don
Gunnyusmc is offline   Reply With Quote
Old 08-09-2006, 06:10 PM   #12
also try www.kustomrides.com good deals on stuff
My Music Site:
Old 08-09-2006, 07:55 PM   #13
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
What about using real sheet stainless? I bought two pieces for my dometic panesl from sheetmetalwarehouse. They look terrific.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 08-16-2006, 10:29 PM   #14
cameront120's Avatar
Profile:  1972 25' Tradewind
I was also going to suggest getting yourself a sheet of stainless cut to the size you need and contact cement it into place. The shop could probably even bend the lip and a backsplash for a reasonable price. The Formica, Nevamar, et al laminates aren't durable enough for using on a counter top. The metal component of the laminate will quickly become scratched and ruined.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 06:31 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 11:01 PM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 08:31 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 07:36 AM
Counter laminate Forrest Cabinets, Counter Tops & Furnishings 1 07-06-2002 07:06 AM
