Old 09-28-2013, 05:18 PM   #1
2007 27' Safari FB SE
Olympic Peninsula , WA
Source for Edgebanding
We've got edgebanding coming loose on the dinette and vanity on our 2007 Safari, This is the plastic edging that looks like the edge of 9-ply Baltic Birch plywood. We like the look, don't want to switch it all to plain wood.
Tried to iron a loose section back down (as a test); the adhesive doesn't appear to be heat sensitive...but the edgebanding certainly is....
Appreciate any suggestions, I've been trying to find it online, no luck so far.
DoubleNickel is offline   Reply With Quote
Old 09-28-2013, 06:11 PM   #2
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Check with local cabinet shops, the ones who actually make them. They seem to have sources we never can find.
tinbender is offline   Reply With Quote
Old 01-27-2014, 07:58 PM   #3
78SovIntl31's Avatar
1978 31' Sovereign
Paris , Ontario
If you haven't had any luck yet, try contact cement.
That is often how laminate is applied anyways.
78SovIntl31 is offline   Reply With Quote
Old 01-27-2014, 10:22 PM   #4
2002 19' Bambi
Lafayette , California
I don't know how that edge banding was originally held in place, but most plastic edge banding is applied with heat. When the original glue fails, applying hot-melt glue to the either the banding or to the edge it is covering will often work. You apply the hot-melt glue, spread it, let it cool, and then iron the banding back in place. Make sure that the iron is not too hot. Excess hot-melt glue will squeeze out. Leave it there until it is cool and hard and then remove it with a file.
Obviously, getting the correct temperature of the iron is critical: melt the glue, but not the banding.
Tim
Tim A. is online now   Reply With Quote
Old 03-11-2014, 04:51 PM   #5
tjp
1973 31' Sovereign
thousand oaks , California
go to Outwater Plastics. they have more types of plastic edging than anyone. use water based contact cement or crazy glue type
tjp is offline   Reply With Quote
Old 03-11-2014, 05:52 PM   #6
65CV's Avatar
Western , Massachusetts
Oakwoodveneer
65CV is offline   Reply With Quote
