Old 10-06-2011, 11:01 AM   #15
Rhonda's Avatar
1956 26' Cruiser Overlander
1970 23' Safari
Lambertville , Michigan
Originally Posted by RTurnConn View Post
My 85 Limited has them throughout. They work fine everywhere except the horizontal tambour on the console in the front. Gets stuck all the time.We open it and just leave it open. Kind of defeats the purpose
Any remedies to make it slide smoother or slide at all!
I was given a tip to use Armour All on the tambour and it worked miracles. All the tambour on my '74 slide with ease now. You might also want to check all the screws holding everything up. If it is not level that will also cause it to not slide correctly. I had to add some more support under my counter to help with that horizontal tambour. Also had an overhead screw coming loose which made the tambour hard to open and close.
Rhonda is offline   Reply With Quote
Old 10-06-2011, 11:34 AM   #16
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Here's a brand new tabour in out '64 Bambi II.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-18-2012, 06:47 PM   #17
SummitAir's Avatar
1970 27' Overlander
Summit , Mississippi
Is that a horizontal because the slats are side to side or is it a vertical because it slides up and down?
SummitAir is offline   Reply With Quote
Old 02-18-2012, 07:44 PM   #18
1974 Argosy 20
Kooskia , Idaho
This may not be the best place to post this idea, but for those of you who have white tambour doors in your AS or Argosy may have found them turning that ugly old banana yellow. Just remove them and use Krylon Fusion white satin spray paint on them and they will look like brand new. Get enough on them to do the front surfaces and that will generally do the V spaces between the slats. It does not look at all like they were painted as the fusion paint does just that, fuses with the original surface. It holds up very well. That same Fusion paint will do the plastic refrigerator vent, and the old yellowed end caps of the units made up to about 1974 or 5. If your AC interior cap has yellowed, take it off and do it too. It makes a world of difference in how old the interior looks.
Old 02-18-2012, 07:51 PM   #19
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
None in our 87 Sovereign
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Tambour replacement? stgerdonly Cabinets, Counter Tops & Furnishings 2 08-02-2011 08:08 PM
frosted coil up panels to replace tambour cabinet faces colsons Cabinets, Counter Tops & Furnishings 0 05-17-2011 11:50 AM
Where can I get a tambour door for my '72 overlander? JackP Cabinets, Counter Tops & Furnishings 4 04-13-2011 11:42 AM
Aluminum tambour Betty3117 Cabinets, Counter Tops & Furnishings 8 03-20-2011 02:44 PM
Want to replace kitchen tambour doors Gkiesel Cabinets, Counter Tops & Furnishings 0 03-13-2011 06:33 PM
