Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-07-2006, 09:50 PM   #1
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Sink Covers Revisited
I've used the search function for sink covers and am wondering if anyone has tried the Camco SinkMates? I've also thought about going to Lowe's and buying several of the white cutting boards and cutting to overlap the 12" X 14" inside dimensions of my sinks. I wonder if a router could be used to take the thickness down that would overlap the edges of the sink or if it would be better to add an additional thickness with the 12" X 14" cutout keeping the top piece in place. How would these two pieces be mated together if I did this?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-07-2006, 11:11 PM   #2
2airishuman's Avatar
Profile:
hi craig......
i am using this camco sink insert cutting board thingie......is this what you are referring to?
i do like it...and as you can see from the pics, it's thin enough to fit under the sink covers without raising them....
it has 4 adjustable rubber stops on the bottom....that when positioned properly....keep it from sliding around in the sink.
as you can see it isn't a perfect fit for the classic sink size....but still works great.
i think in the close up (#4), you can just see one of the black bumpers....this was before i adjusted them the 2nd time a little tighter....
cheers
2air'
Name:	sink with camco 1.jpg
ID:	18292   Click image for larger version
Name:	camco in sink 2.jpg
Name:	camco in sink 3.jpg
ID:	18294   Click image for larger version
Name:	camco in sink 4.jpg
Old 02-07-2006, 11:51 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
I do not have sink covers. Has anyone made them from butcher block? I was thinking of cutting them a little bigger then the sink and then routing the bottom to fit in the hole. I would like to hear what you may have done........
Richard
Charter Member Four Corners Unit
Old 02-08-2006, 06:05 AM   #4
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Well, I have the sink covers for my Argosy, but this may be the place to ask another "kitchen" question. The Argosys didn't come with the burner top cover. It is the same stove that's in the Airstreams of that era, but just didn't come with that stainless cover. Anyone know where you can buy that cover and retro fit it. I think it should work. Any input?
juel is offline   Reply With Quote
Old 02-08-2006, 06:13 AM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
You can, and I did with our Argosy. I picked up a cover at the rally flea market, and installed it in about 30 minutes, before we even left the rally the next morning.
(No Longer at Inland RV)
Old 02-08-2006, 08:23 AM   #6
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Thanks, I'll have to start lookinig for salvage parts. Good to know it can be done.
Old 02-08-2006, 10:05 AM   #7
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Stainless cover for stove
Judy, I may still have one in my garage if you are interested? Just let me know (PM) and I will try to dig it out from all my restoration parts. Ed
BIGED52 is offline   Reply With Quote
Old 02-08-2006, 01:00 PM   #8
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
Exclamation Wooden Cover
I once cut and routed a wooden cutting board to fit the sink. Covers a multitude of sins hiding in your sink, including a pot of water to soak off the dried oatmeal from breakfast.
Went inside the coach a few weeks later to get her ready for the next outing. The board had warped up about an inch and a half on each side from the evaporating water.
Cut the next one from plastic.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 02-08-2006, 04:21 PM   #9
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
I took the time to make a butcher block sink cover with my new table saw I got for Christmas. Had some maple laying around from a garage sale and wanted to put it to good use. Made the cover, routed the bottom edge enough to fit the sink and rounded the corners so the radius would match the corners on the sink. It came out great. I was sooo proud. Left it in place in the trailer during the following week and went out on Saturday morning and it had warped slightly. Still undecided about whether I want to route it some more to make it fit or what. I'll probably get over my frustration and make it work. Then I get to make a second one.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 02-08-2006, 07:40 PM   #10
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Liquid Nails
Originally Posted by davidz71
.....add an additional thickness with the 12" X 14" cutout keeping the top piece in place. How would these two pieces be mated together if I did this?
I used "Liquid Nails" to mate the granite sink covers with plywood "insert stops" on the 345.
Name:	Granite Inserts.jpg
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 02-08-2006, 07:55 PM   #11
davidz71's Avatar
Dennis, sharp looking counter. I wish mine looked that elegant.
Craig
AIR #0078
3.73 rear end
Sink Covers Dwight Cabinets, Counter Tops & Furnishings 22 12-12-2002 06:52 PM
Tire covers Andy Fay Tires 1 11-16-2002 07:03 AM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 12:57 PM
Window Covers kzener40 Airstream Motorhome Forums 5 09-16-2002 03:07 PM
sink covers Larry Brown General Motorhome Topics 1 06-28-2002 10:35 PM
