Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-25-2002, 06:52 AM   #15
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Pictures of 15 dollar cutting baord
My HD 15 dollar cutting board........
Name:	airstream interior 013.jpg
smily is offline   Reply With Quote
Old 09-25-2002, 08:50 AM   #16
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
My wife tells me cutting boards need to be oiled to keep water and bacteria from getting down into the wood pores. I'd assume this would also mean the underside of boards exposed to moisture from the sink trap. And she says it has to be some kind of oil that doesn't go rancid. She has a bottle of something labeled as cutting board oil... probably the expensive version of an oil available cheaper elsewhere.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 09-25-2002, 08:58 AM   #17
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
...probably the expensive version of an oil available cheaper elsewhere.
Way to funny.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 09-25-2002, 10:07 AM   #18
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Actually that's true....
You do need to keep wood cutting boards oiled, but it's not to protect from trap moisture. It's to help the wood resist absorbing moisture from foods.
The type of oil needs to be okay for food use, but olive oils & such, do go rancid and wouldn't be a good to use.
Shari
Old 09-25-2002, 10:19 AM   #19
BobbyW
BobbyW's Avatar
Houston , Texas
I found this Cutting Board link kind of interesting.
http://www.whatscookingamerica.net/C...s/AllAbout.htm
"Wooden boards need oiling once a week to seal the grain against bacteria. An oil finish helps to prevent the wood from cracking or pulling apart at the seams. Use a product that is (1) edible; and (2) tasteless. USP-grade mineral oil is a popular choice as it is the cheapest pure food-grad oil you can buy (do not use vegetable or olive oil because it can turn rancid). Before applying oil to butcher block, warm the oil slightly. Apply oil with a soft cloth, in the direction of the grain, allowing the oil to soak in. Allow oil to soak in a few minutes, then remove all surface oil with a dry, clean cloth.
Some professional cooks like to add a little beeswax to the mineral oil for a tougher finish. Simply shave about 1/2 teaspoon beeswax into a microwave safe dish with a cupful of mineral oil; microwave on high for about 45 seconds. Apple to the cutting board or butcher block while still warm. Save of dispose of the remainder of the oil."
And for the Microbiologist..
http://www.hi-tm.com/Documents/Cutboard.html
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 09-25-2002, 10:40 AM   #20
RoadKingMoe
Beavercreek , Ohio
Thanks, BobbyW! I really got a lot out of that, especially the second one.
Maurice
AB8XA
WBCCI 5446
Old 09-25-2002, 12:55 PM   #21
gwsullivan
gwsullivan's Avatar
Profile:
Wow, a little vinegar and water is more effective than the high priced sanitizers.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 09-25-2002, 01:59 PM   #22
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
My experience is that the old stuff almost all ways works better than the newfangled ones that promise to do this and that. My father owned an industrial commercial chemical sales company and the stuff off the shelf is so watered down that it is almost better to use plain old soap and water.
Besides if vinegar smelled good, most of the chemical companies would not have a product to sell. I try to buy commercial or in concentrate so I can control the strength of what I am using.
I did find it interesting the info that is now available on wood vs. plastic. Our plastic ones go in the dishwasher after every use, and I have a veggie board and a meat board that I use exclusively for the individual foodstuffs. I quit using wood 15 years ago because at the time the research said wood was botulism waiting to happen. Now I find out that the plastic ones are dulling my knives aaarrrgggg
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-12-2002, 05:52 PM   #23
Gordon Watt
Gordon Watt's Avatar
Profile:
Butcher Block Sink Covers
Try to find the butcher block off a portable dishwasher. It works wonderfully well. You have to cut it to fit of couse.
Gordon Watt is offline   Reply With Quote
Ceiling light covers loudruff Parts Archive 8 07-28-2004 11:26 AM
light globe/light covers David Hall Electrical - Systems, Generators, Batteries & Solar 5 02-18-2004 06:35 AM
advice wanted for bathroom sink replacement Shelby Copeland Interior Restoration Forum 8 12-25-2003 07:06 AM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
sink covers Larry Brown General Motorhome Topics 1 06-28-2002 09:35 PM
