Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-17-2006, 03:53 PM   #1
Siamese66's Avatar
Profile:  1976 25' Tradewind
Seattle , Washington
Shower curtain replacement?
I need to replace my original shower in my 75 Tradewind. Would anyone have a suggestion for a replacement? Any help would be appreciated.
Rick
Siamese66 is offline   Reply With Quote
Old 10-14-2006, 09:03 PM   #2
near ichnetucknee springs
charlie tuna's Avatar
Profile:  1978 31' Sovereign
davie , Florida
we have a 1978 sovereign with a rear bath. this originally had a sliding shower door which was replaced by the p.o. with a curtin rod arrangement. the curtain was hooked around the square shower door channel. i removed that channel and installed an aluminum round 28 inch rod which had stainless steel supports. this mounting was reinforced with aluminum back plates. we then found a clear shower curtain which allows plenty of light into the shower. all the eyelets were used except the last two. the last two was supported by velcro patches which attached to the shower wall. it really works out nice and keeps the water inside the shower. we also matched the clear shower curtain up with a clear shower mat. all this "stuff" was found at walmart..................
charlie tuna is offline   Reply With Quote
Old 10-14-2006, 11:38 PM   #3
CaddyGrn's Avatar
Profile:  1963 16' Bambi
Yreka , California
Replace your shower curtain, or entire shower?
If your curtain and you want same configuration ~ post a picture. You may get more answers to give you choices! Good luck.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 10-15-2006, 07:08 AM   #4
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
The clear curtain is a good idea.
Why aren't there lights in the shower?
I'm thinking about adding a waterproof light, anyone done that?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 01:06 PM
Blinds for my 1964 Safari Neenm Upholstery, Blinds, Walls & Interior Finishes 19 09-18-2003 05:33 PM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 03:04 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 10:03 PM
