Old 09-13-2010, 04:34 PM   #1
2002 27' Safari
Churchville , Maryland
Safari Wardrobe Door Hinges Loose Adjustment
My 2003 Safari has one wardrobe door whose hinges loose adjustment on just about every trip over 200 miles. The other doors use the same hinges but don't have the same problem. The hinges are Grass type 3000 which are likely available. My only concern with replacing them is that removing and reinstalling screws in plywood doesn't always give a satisfactory outcome.
Does anyone have any experience working with these hinges, possibly using a thread locking product prior to adjustment?
Thanks for any replay.
Cable is offline   Reply With Quote
Old 09-13-2010, 05:51 PM   #2
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
I carry a small bottle of Gorilla glue just for such things as setting screws that won't hold in particle or plywood.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup,
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 09-13-2010, 07:09 PM   #3
Have you made sure that the "running gear" is properly balanced?
If not, then vibration will always loosen things up, especially screws.
Old 09-14-2010, 06:08 AM   #4
2002 27' Safari
When you say "running gear" I assume it means balancing of the tires? The tires were balanced when they were replaced this past spring. My problem is with one door and has been going on since before the tires were replaced. A tire out-of-balance problem would likely have effect on all doors?
Do these hinges have a history of loosing their adjustment?
Thanks for the replies.
My Entry Door Hinges Are coming Loose SaabLover Exterior Storage Compartments & Access Doors 18 08-05-2012 05:07 PM
Wardrobe door change tport40 2007 Safari SE 5 10-14-2007 10:26 AM
Door hinges loose Blimphauler Doors & Locks 7 11-20-2006 03:22 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
hinges on wardrobe losen bfwoz Cabinets, Counter Tops & Furnishings 5 10-08-2004 06:04 PM
