Old 09-14-2014, 01:47 PM   #1
1973 31' Sovereign
Fairmount , Georgia
Smile Roll up cabinet door replacement?
My husband and I just started our reno today! I've been checking out the forums for a while but this is my first question!
We have a 1972 31' Sovereign. The existing cabinets are in good shape except for the roll up sliding doors. Some are stuck, and some are sticky and you have to really push/pull to get them up and down. Is it possible to replace the roll up doors? Does anyone sell them? I haven't had luck finding replacements online.
Thanks!
kbarrett12 is offline   Reply With Quote
Old 09-14-2014, 02:02 PM   #2
1981 31' Excella II
New Market , Alabama
Get some silicone spray. It helps fix most of the sticky problems. The big problems are when the PO cuts them because they get tired of them sticking. It comes back to poor maintenance. Apply the spray to the track upper and lower.
Perry
Old 09-14-2014, 03:42 PM   #3
1973 31' Sovereign
Fairmount , Georgia
Thanks! will try it!
Old 09-14-2014, 05:00 PM   #4
1982 31' Excella
Hemingford , Nebraska
Tambour listed in parts forum. He will cut to size. http://www.airstreamclassifieds.com/ads/tambour-3/
mwernke is offline   Reply With Quote
Old 09-24-2014, 01:37 PM   #5
Originally Posted by mwernke View Post
Tambour listed in parts forum. He will cut to size. Tambour
The tambour door material can be ordered from parts stocking dealers, and some even cut it to your dimensions.
At least that way you would know that the material is fresh.
Andy 15700
Old 09-24-2014, 06:03 PM   #6
1981 31' Excella II
The stuff is more expensive per ounce than gold.
Perry
Old 09-24-2014, 08:18 PM   #7
Perry
Perry.
Not cheap, but first class stuff.
A 4 X 8 sheet is cheaper than cut pieces, by the square foot.
A lot of waste when cutting them to size, plus a little labor.
2008 19' Bambi Roll Away Shower Door lkoenig Plumbing - Systems & Fixtures 3 01-25-2013 03:45 PM
Is there a fix for a roll away (tambour) door on 76 Sovereign Hummer Cabinets, Counter Tops & Furnishings 2 07-21-2010 04:54 AM
Replacement 'Roll-Up' Shades Andreasen Upholstery, Blinds, Walls & Interior Finishes 9 01-10-2008 06:27 PM
Suggestions for Roll Cabinet replacement BurnBound Cabinets, Counter Tops & Furnishings 4 03-06-2005 01:38 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
