Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 10-10-2007, 09:54 PM   #1
Profile:  1966 26' Overlander
Conover , Ohio
roadblock in 66 Overlander
I have been gutting the interior of my 66 Overlander to relace the floor in the bathroom. I have found a few hidden screws, cut a few rusted screws, and ran across a few tiny brad nails in the upper cabinets, no major surprises. I finally hit a roadblock. The right closet in front of the tub is not coming out easily. The front is loose, it is hung up in the rear. It looks like there are quite a few small round head nails (red arrows) holding the shower wall to the upper cabinet AND the closet. If this is the neat step, how do I remove these round head nails? I tried to hammer from the inside the closet, and it almost seems that it is glued as well as nailed. Anyone help would be appreciated. I'm just trying not to break anything if I can help it. Thanks, Tom
air66stream is offline   Reply With Quote
Old 10-11-2007, 04:04 AM   #2
thinking outside the box
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
would a small cats paw pull them? the shape pulls the head of almost all fasteners through small taps. Once you get it going put some thin wood between the cats paw and the cabinet so the wood does not get damaged.
Frank Yensan The Airstreamer's Club MD-1 founding member "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 10-11-2007, 04:46 AM   #3
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Take the whole thing out
I ran into similar issues with my '56 interior. Removing the nails will do no good if the seam is glued. Look at taking the entire unit out by removing the aluminum channel on the wall.
I tried knocking out a panel and it split. No biggie now, since I'm rebuilding all the cabinets from scratch.
Good luck.
D
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 10-12-2007, 09:12 PM   #4
Conover , Ohio
got em
Well, I got the panel off without destroying it. The nails were spiral cut with round heads. It made them tough to get out. The panel wasn't glued at all. I think the nails just held so well it just seemed like it was glued when I hit it from behind. I am amazed at how well this old thing is put together. Next step is to remove the upper cabinets, then start on the bathroom itself. Thanks for all the input. Tom
Old 10-12-2007, 09:39 PM   #5
Silver Hilton
Mark Wiltrakis's Avatar
Profile:  1992 29' Excella
1959 24' Tradewind
Hillsboro , Oregon
Tom -
I encountered the same problem removing the wardrobe closet in my '59 Tradewind. Hammering from within the wardrobe was not helpful, but driving a thin two-inch wide putty knife between components from the outside, very carefully from floor to ceiling, allowed me to pull one nail at a time. I did not encounter any glue, but the nails made a VERY snug connection between the wardrobe pieces. I stalled at this point in my interior removal for several days until I was able to start wedging the two surfaces apart with the putty knife. Good luck -
Mark
Mark Wiltrakis is offline   Reply With Quote
Help ID overlander Walt Stanton 1970 Overlander 10 10-17-2009 09:11 PM
57 Overlander gregjudy Windows & Screens 4 05-03-2007 08:48 PM
58 overlander uncledaddy Towing, Tow Vehicles & Hitches 5 03-10-2005 03:26 PM
58 overlander in need ! scooter 1958 - 1963 Overlander 6 12-29-2002 10:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
