Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-30-2008, 11:17 AM   #1
TennisMan
Profile:  2007 25' Safari FB SE
Kennesaw , Georgia
Question Rickety dinette table
I have an '07 25' Safari FB SE; the dinette table is rickety. That is, it has a lot of play in the upper brackets that hold it in place, so when you put an elbow on the table it moves down on your side and up on the other. Adjusted the single leg with no luck.
The dealer managed to get it firmly set, but the first time we moved the table we're back to wobbling again. There appears to be no way to adjust the wire support to move the table up higher in the catch brackets.
Ideas?
Lance
TennisMan is offline   Reply With Quote
Old 06-30-2008, 12:55 PM   #2
Airhog1
Airhog1's Avatar
Profile:  1975 31' Sovereign
Searcy , Arkansas
Hey Lance,
There is a bulletin out from Airstream on this issue...we just had to do one for Chief that was the same way.
You have to go in under the window and pull the alum. back and add more support behind that...you must drill out the rivets and remove the window trim to do this.
Your dealer should have all the instructions on how to do this...if not, the factory will fax him all the info.
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 06-30-2008, 03:58 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Mine has done it since day one. Another picture of a well engineered product.
I don't suppose this is being covered for folks that are out of warranty? Oops, did I really just ask that?!?
Old 06-30-2008, 04:22 PM   #4
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
I'm not sure how the Safari Dinette tables attach to the wall, but I took two index cards and folded them - then inserted the two tabs on the table into the folds and put that combination into the slots on the wall of our CCD to get it to stop wobbling. Sort of like Tab A into Slot B but I wrapped Tab A in a folded index card before inserting into Slot B.
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 07-01-2008, 06:37 AM   #5
Isadora
Profile:  1976 Argosy 24
Joplin , Missouri
I had the same kind of problem with the dinette table in the Argosy, and I took a leftover bit of weatherstripping (the kind with the sticky back) and put it in each of the tabs. No more rocking.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
Isadora is offline   Reply With Quote
Old 07-01-2008, 07:32 AM   #6
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
I stuck a thick piece of tape at each hinge. Solved the wobble.
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
henw is offline   Reply With Quote
Old 07-03-2008, 01:42 PM   #7
TennisMan
Kennesaw , Georgia
Thanx, took care of it by wedging some rubber material into the tabs.
A/S tech support says that the under-table support wire must be too low and would have a dealer re-position the lower support brackets for the wire. Might do that, but don't want any screw holes exposed from moving the supports up half an inch or so.
Lance
Old 07-03-2008, 04:55 PM   #8
yakman
yakman's Avatar
Profile:  2007 25' International CCD FB
Gahanna , Ohio
tennisman,
you are not alone. mine does it as well. I thought maybe it was someone telling me I shouldn't be putting my elbow on the table.
I'll be looking for a wedge or strip of sorts to stiffen it up.
-yakman
yakman is offline   Reply With Quote
Old 08-05-2008, 02:44 PM   #9
ESCAPE POD
ESCAPE POD's Avatar
Profile:  2007 19' Safari SE
Seal Beach , California
Our dinette table just started loosening up on a recent trip. I was sure that I was the only one with this issue! Sure pays to check out the forums before tackling a problem! Thanks, Steve & Susan; your "fix" sounds like it's worth trying before the remodel suggested by the factory.
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time. -T.S. Eliot
Jerry & Susan
2007 19' Bambi SE
2003 Dodge Dakota 4.7L V-8
ESCAPE POD is offline   Reply With Quote
Wobbly dinette table flyfishfred General Interior Topics 4 01-21-2008 10:19 AM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
Dinette Table Devoman Cabinets, Counter Tops & Furnishings 2 03-11-2006 05:18 AM
WANTED: T-Leg for Dinette Table Cat Parts Archive 3 08-13-2004 03:48 PM
Dinette table ALANSD General Interior Topics 7 03-14-2004 10:01 PM
Forums Directory
