Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-01-2009, 08:10 PM   #1
bh53olds's Avatar
Profile:  1975 25' Tradewind
oakhurst , California
Replacing Tambour doors
Can anyone tell me how to install new tambor under the kitchen counter in a 73 overlander?
bh53olds is offline   Reply With Quote
Old 02-01-2009, 08:25 PM   #2
Profile:  1973 27' Overlander
Loganville , Georgia
Somebody posted this question the other night and I posted this youtube airstream restoration video for tambour doors replacement.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-01-2009, 08:38 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
This may prove helpful:
Tambour Undersink Door
Tambour Doors Repair
Tambour Door
New tambour is available.
Old 02-02-2009, 01:54 AM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
This is how I did it. Try to take out the faux walnut trim without breaking it (you probably will, but can glue it back together) on the vertical aluminum extrusion on the right corner of the counter. Drill out the rivets and remove the extruded aluminum. This will give access to the track.
I also cut the tambour into 2 equal lengths so that the whole piece does not have to go into the spiral track. The longer the tambour the more likely problems are to occur.
Pay no attention to the man behind the curtain- WoZ
Old 02-06-2009, 10:34 AM   #5
bh53olds's Avatar
Thank you all for your help. I'll let you know how it comes out.
Old 02-06-2009, 10:37 AM   #6
bh53olds's Avatar
Lothlorian
Thanks, I did see this video, but my tambour does not have a spring closure. The problem is how to get the tambour back in place under the counter?
Old 06-08-2009, 09:46 AM   #7
tinsltootsie's Avatar
Profile:
Images: 27
Smile kitchen tambour replacement
I was looking for how to replace kitchen tambour, and saw your post. Have you tried to do this yet? How did you make out? I just finished the overheads, and they look great. I am shying away from the galley area because of the curved config, and all that it seems to curtail. So please update me with any info you gain. Thanks
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 06-13-2009, 11:59 PM   #8
coairstream's Avatar
Profile:  1972 25' Tradewind
Denver , Colorado
Are you looking for tambor?
coairstream is offline   Reply With Quote
Old 06-18-2009, 10:57 PM   #9
RichHog's Avatar
Houston , Texas
I replaced the Tambour below the sink in my Tradewind. Bought Maple tambour on the web and stained with Minwax. It's a near perfect match to the 72 plastic laminate and looks much better. It sticks some in the bottom track cause it's bend some but slides back into the corner box. I cut about a 6" piece and fixed to the right side corner so that the left section doesn't have to slide all the way across. Took some work to slide into the track but is doable.
RichHog is online now   Reply With Quote
Tambour Doors InsideOut Cabinets, Counter Tops & Furnishings 2 11-10-2007 09:09 PM
Tambour Doors AluminumLuvr 1980 Caravelle 14 08-09-2007 11:40 PM
Replacing credenza and lower tambour doors Lumatic Cabinets, Counter Tops & Furnishings 2 01-14-2007 12:04 PM
Tambour Doors jmcoste Member Introductions 7 04-09-2006 10:33 AM
cost of replacing all tambour doors pearl Cabinets, Counter Tops & Furnishings 9 08-17-2004 06:11 PM
