Old 01-01-2019, 07:03 AM   #1
VDR928's Avatar
2012 23' FB International
Charlotte , NC
Replacing countertop
We are going to replace the countertop in our 2012 International Serenity 23FB. How hard is it to remove the stove, sink and faucet? Any tips will be appreciated.
VDR928 is offline   Reply With Quote
Old 01-01-2019, 09:50 AM   #2
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
If it’s like the FC nothing is hard, just don’t force anything, there’s probably another screw you didn’t find. The metal band that holds the top to the sidewall is hard to get to. Instead of removing the top from the band I ended up removing the band from the wall and leaving the band attached until I could get the top out. After I made the new top I reattached the band to the new top and could then reattach to the wall. That make ant sense?
Llittle54 is offline   Reply With Quote
Old 01-01-2019, 09:58 AM   #3
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Remove the sink first, makes getting to some of the screws much easier.
sheriff1 is offline   Reply With Quote
Old 02-19-2019, 07:51 PM   #4
VDR928's Avatar
Charlotte , NC
Countertop is in!
Many thanks for the help... it really was easy using the old one for a template.
Old 05-07-2020, 02:45 PM   #5
2012 30' Flying Cloud
Morongo Valley , California
That made perfect sense!
I have removed all the screws from the band going into the wall but there are 3 large rivets left to remove. The part of the rivet that you can see is about a half inch across. Have not seen rivets like this before. Did you have to remove those.
I’m wondering if they are holding up something up I can’t see inside the wall.
Alan 117 is offline   Reply With Quote
Old 05-10-2020, 09:25 AM   #6
Llittle54's Avatar
2016 16' Sport
I do remember those rivits. If they were holding up something important I haven’t found out yet!
Old 06-30-2020, 12:11 PM   #7
2018 16' Sport
St. Louis , Missouri
What material is your new countertop? Looks great.
Sport 16 STL is offline   Reply With Quote
Old 07-01-2020, 01:39 PM   #8
VDR928's Avatar
Charlotte , NC
If you are asking about ours it is concrete-looking laminate from Ikea. It was very inexpensive and still looks like the day we installed it! Pretty lightweight, too!
2012 23FB International Serenity #Dorytheairstream
2019 GMC Sierra 1500 Crewcab 4WD Denali
"Denali & Dory"
Doing the countertop lean tandemfish Cabinets, Counter Tops & Furnishings 1 11-16-2004 05:19 PM
OSB for countertop base? TomW Cabinets, Counter Tops & Furnishings 4 05-25-2004 02:08 PM
Countertop edging Jenturnr 1984 - 1989 Sovereign 5 05-20-2004 08:34 AM
aluminum composite countertop repair? Janet H Cabinets, Counter Tops & Furnishings 1 09-30-2003 09:38 AM
New Countertop smily Cabinets, Counter Tops & Furnishings 38 07-01-2003 06:16 AM
