Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-28-2008, 11:20 AM   #1
bookman's Avatar
Profile:  1972 Argosy 20
youngstown , Ohio
replacing CABINET/storage door hinges.
Hi folks.
I just got my 1970 Overlander yesterday, it's in great shape but needs some TLC, and I am wondering if anybody else has had this problem.
It looks like all the LOWER/floor cabinet doors had originally been secured by a plastic hinged material that was simply stapled to frame and door.
This probably started to let go about the time Ronald Reagan took office.
Frankly I would rather NOT install all 'real' hinges that low.
Any ideas?
Lou.
bookman is offline   Reply With Quote
Old 08-01-2008, 11:07 PM   #2
bookman's Avatar
youngstown , Ohio
I am considering building actual DRAWERS onto the cabnit fronts, but think I'd lose a buncha space that way.
Old 08-03-2008, 03:36 PM   #3
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
I'm confused
Originally Posted by bookman View Post
... It looks like all the LOWER/floor cabinet doors had originally been secured by a plastic hinged material ... Frankly I would rather NOT install all 'real' hinges that low. ...
What is a 'real' hinge?
My Overlander, according to InlandRV's site, uses the same door latches. So I assume the doors are similar.
But, my Airstream has metal hinges on all the doors.
I noticed you have a photo gallery. Please post a picture of the plastic hinged material.
Tom
Old 08-03-2008, 04:50 PM   #4
Commercial Vendor
Profile:  Corona , California
Hi folks.
Any ideas?
Lou.
You upgrade the hinge setup.
You reverse the door and install a piano hinge.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-04-2008, 08:08 AM   #5
bookman's Avatar
youngstown , Ohio
yeah, that was my take too, thought there might be another way. never hurts to ask.
Old 08-04-2008, 12:23 PM   #6
Profile:  1969 31' Sovereign
1967 26' Overlander
Alex , Oklahoma
I had considered piano hing, but (9) would be a chunk out of the pocket book. My doors still had the plastic edge. So I pulled out the stapels cleaned up the inside where it use to be hinged. I bought small one inch hinges put one on each end and one in the middle. Then took my plastic stip cut out the inside of the stip where the one inch hinge fit and slid the plastic strip back into place. Stapled the plastic strip on the inside. This covers up the raw edge that is exposed when the door is closed.
I was lucky I had all the origional plastic stips the P/O had threw them away. The PO did staple orange webbing over them when the plastic hinge broke. Sure was red neck looking.
1969 Sovereign 31'
AIR #18751
CJ of Okla is offline   Reply With Quote
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 10:39 AM
Door Hinges Ed Keyes Doors & Locks 4 09-06-2006 04:48 PM
hinges under gaucho storage bins mimibeth Cabinets, Counter Tops & Furnishings 2 07-22-2006 03:30 AM
hinges for a 63 entry door? 59er Doors & Locks 7 05-03-2005 08:37 AM
How to refasten door hinges! pipsmith22844 Doors & Locks 14 03-16-2004 07:17 AM
