Old 03-09-2012, 02:55 PM   #1
lewishw's Avatar
1978 31' Sovereign
Colorado Springs , Colorado
Repairing or rebuilding Tambour cabinets?
I have a 1978 Sovereign with the vinyl tambour cabinets in it but most of them are pretty rough. They have cracks in them, the ends are ugly and banged up, etc. What are my best options for repairing or replacing them? does someone manufacture replacements? Should I pull them out, strip them and fiberglass over the existing structures? Start from scratch? Please tell me what to do! I would like to replace the doors with the stainless steel material, but I have to revive the cabinets first. What do y'all think?? There may be threads buried in here that cover exactly this topic, but I have been unsuccessful in finding them.
Thanks guys!
Hunter
lewishw is offline   Reply With Quote
Old 03-09-2012, 03:07 PM   #2
1981 31' Excella II
New Market , Alabama
Tambour is expensive. If the actually tambour is missing or damaged it will be very expensive to replace them. If you like the tambour you can design new cabinets using the old tambour. You can make new end caps our of wood of the whole thing. Pay attention to weight when you re-design. Solid wood is heavy. Best to have solid wood frames and 1/4 plywood panels.
Perry
Old 03-09-2012, 04:25 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I'm kind of glad that the tambours came out in later models. But I have kind of wondered if it wouldn't be possible to replace them with a newer tambour kit. Here's one from Rockler:
Tambour Door Hardware Kits - Rockler Woodworking Tools
Lynn
WBCCI 21043
Old 03-09-2012, 04:56 PM   #4
larry b's Avatar
1975 31' Sovereign
howell , Michigan
V-3-MA501 36" W Tambour Door Maple by Omega National Products - up to 29% off - CabinetParts.com
I purchased this for my 1975 and replaced it worked well.
larry b is offline   Reply With Quote
Old 03-09-2012, 06:33 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
We went to sliding doors that webspinner made that fit right into the tambour tracks. Here's an image from our blog:
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-25-2012, 07:54 AM   #6
1978 31' Sovereign
Nicholasville , Kentucky
I just took all mine out of a 78 to replace all the cabinets, I own a cabinet shop and want my cabs in mine. Send me Picts of your kitchen and I probably have the tambour you need. If you want the stainless look its not that hard. Rustoleam makes a stainless paint for appliance and cab refinishing. Remove the tambour and place over a round object like a 5 gal bucket to paint. I replace tambour in kitchens all the time. Hope this helps.
Bgreen is offline   Reply With Quote
Old 03-25-2012, 09:04 AM   #7
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
My wife came home with 2 Bamboo rugs for our 31' 1970 and as I unrolled them all I saw was lightweight tambour. It cuts good on a table saw and has a strong backing. If you search bamboo rugs on Amazon.com you can get some nice ones at a good price. They are lots lighter so I had to put pins in them when we travel but they are working out great. I used the rest of the "rugs" for the panels in the new refer.
geezernbabe is offline   Reply With Quote
Old 03-25-2012, 09:33 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Perry
Buying tambour cut to size is a bit pricy. Buying it by the sheet and cutting it yourself is more reasonable.
There are multiple threads on tambour repair. I used aluminum tape across the tambour glued to ballistic nylon with contact cement. Still working.
If you want your cake and to eat it too, others have glued old tambour to new cabinet door panels.
Old 03-25-2012, 12:09 PM   #9
1981 31' Excella II
I seem to remember is was like $500 for a sheet and that may have been a half sheet and I don't think that was even wood for that price.
Perry
Old 03-25-2012, 03:15 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Here are 3 tambour suppliers:
Woodworking Supplies - Cabinet Hardware | Woodworkers Hardware ($200- $250 3'x5' sheet)
Tambour panels & doors
www.winonamanufacturing.com
Old 03-25-2012, 03:35 PM   #11
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
After I finish with a couple of more expensive, higher priority repairs, I am going to have to tackle the Tambour problems in the galley. My first obstacle will be to figure out how to get the new material into the existing tracks? I guess I will have to start by disassembling the cabinet trims?
I like post #4 and will follow up on that location. The cost appears reasonable compared to others - as long as the stock size is large enough for the big run under the sink.
litlgeezer is offline   Reply With Quote
Old 03-26-2012, 06:19 AM   #12
lewishw's Avatar
1978 31' Sovereign
Bgreen and Geezer,
Would you guys mind either posting or emailing me a couple of photos of your results? I had considered the silver paint route, but I don't know if some of my tambour is in good enough shape to just paint it. The bamboo rug idea is absolutely brilliant. I would love to see how that looks. Also, the ends of my cabinets (where they have vinyl padded caps) have some cracks. Any ideas on how to clean those up? I don't know if I can jus pull the caps off, glass over the ends and cracks with fiberglass resin and then paint the whole bodies, or what to do. Bgreen, you said you are a cabinet builder, I would love your thought on what I should do with the damaged cabinet bodies! Thanks a bunch guys! If its easier to email me the photos, my email is hunterwlewis@gmail.com. Looking forward to hearing from you guys!!
Stream on!
Hunter
Old 03-27-2012, 09:28 AM   #13
1970 31' Sovereign
Here are a few pics of bamboo tambour I hope it 's been awhile hope it works out. It fits good in the plastic rails.
ID:	154415   Click image for larger version
ID:	154417   Click image for larger version
Old 03-27-2012, 09:40 AM   #14
1980 31' Excella II
Ocean View , Delaware
Beautiful
Wow, that looks beautiful. What did you use for your backsplash? What a great re-do!!
Sue
Disneysue925 is offline   Reply With Quote
Solo Considering a 23D or a 25FB Twin need counsel rodsterinfl Solo Streamers 38 09-10-2013 04:38 PM
What size truck or SUV is best? Marinablue Towing, Tow Vehicles & Hitches 265 04-20-2012 11:39 AM
Couches or Recliners PamCheshire General Interior Topics 19 03-12-2012 11:21 AM
Can 1990 1/2 ton 4x4 Suburban tow a 26 or 28 ft Airstream mudsummer Towing, Tow Vehicles & Hitches 7 03-09-2012 01:26 AM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 03-06-2012 06:50 PM
