Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-27-2003, 05:05 PM   #1
Profile:  1986 32' Excella
vledder , drenthe
repaired the tambour doors
I just repaired the 4 tambour doors in the bedroom of my 74 overlander
it realy is verry simple
1 remove the tamours
2 trim al the strips with a sharp stanly knife
3 align the strips with tape
4 cut a piece of linnen a bit to big
5 use spray glue on both the linnen and the strips
6 R.T.F.M for the glue
7 aply the linnen on the back of the strips
8 wait
9 cut the linnen with the stanly knife about 1/2 inch from the side
10 ready
it realy is verry simple I did the 4 door in 2 hours plus 30 minutes for the removing and reinstall
total cost
euro 6 for the linnen still have half of it left over
euro 12 for the spray glue BISON still have left over
euro 60 for the new jeans I wasted with glue
when evrything is so simple as this I have the trailor ready in a month
Remco
remcolent is offline   Reply With Quote
Old 12-28-2003, 12:17 AM   #2
qqq
qqq's Avatar
Profile:
Thumbs up
Remco "The flying Dutchman"
Don't throw away the glue & old Jeans...when I drive thru NL on my way to Vastera Sweden , you can have more fun and repair a few of my tambours
Hart
qqq is offline   Reply With Quote
Old 12-28-2003, 11:32 AM   #3
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Question Type of Spray Glue?
Remco,
What type of spray glue did you use? Spraying both sides implies to me that you used a contact adhesive. Is that what you used?
This may be a project I will have to take on. I only have two bad tambour doors at this time but after 33 years the glue is brittle and ready to give up at any time. It might pay to just redo them all rather than wait or chance failure.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 12-28-2003, 04:43 PM   #4
vledder , drenthe
qqq if you are going to zweden you'r welcom to spend the night here and we can fix the tamboutdoors I'm in the north part of holland
I used a spray glue that needs to dry for 15 minutes before you glue the thing together its just a basic glue that is good for linnen and wood or plastics
Remco
Old 12-28-2003, 11:27 PM   #5
qqq
qqq's Avatar
Profile:
Remco,
Thanks for your offer, I have only 2 small tambours under front sofa that need some attention, but I'll be glad to say hello, on my way to www.bigmeet.com
Have you ever been there? it's AWSOME
Hart
Old 01-13-2004, 11:13 AM   #6
Confused & Wandering
Theo's Avatar
Profile:  1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
I have problems with those strange things too. The large on under the counter needs new every thing.. Where can I find such, or do I need to make one,
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 01-13-2004, 11:20 AM   #7
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Theo,
Run a search on Tambour someone posted some links a while back to suppliers for the tambour material, typically a cabinet/furniture maker supply house. I have several on my 75 that need attention...but they are kind of low on the priority list.
Aaron
Old 01-13-2004, 04:22 PM   #8
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Tambour Source
Here it is:
http://www.winonamanufacturing.com/index.shtml
this should be very close, if not identical, to the original wood tone used nt he 70's trailers.
http://www.winonamanufacturing.com/d_woodtone.shtml
Uwe
www.area63productions.com
Old 01-13-2004, 04:28 PM   #9
Profile:
Make the tambours
It is not hard to make tambours. I did for some of the openings on our 71 Safari. I used walnut wood. Planed it down to the correct thickness, ripped to the width and then ran each piece by the router with a 45 degree bit. Then glued them with yellow glue to artist canvas. No problem, just some tedious work. Results are worth the work.
Dan
Dbraw is offline   Reply With Quote
Old 01-13-2004, 04:44 PM   #10
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Cabinet & Counter Tops > repaired the tambour doors
Greetings Theo!
Welcome to the world of Vintage Airstream ownership!
Another source for both the tambour and tracks to mount it in is:
Tape Ease
The URL in the above link will take you to the veneer products. In the restoration/refurbishment of my Minuet, the Birch Veneer was used to replace the upper tambours that were originally an off-white plastic veneer - - the Birch was stained with a pickling-stain that compliments the white vinyl covered aluminum that makes up the cabinets in the Minuet. They have a number of veneer woods that can be stained to match or compliment the balance of your cabinetry. In addition, they have a wide variety of mounting hardware for tambour doors as well.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 01-13-2004, 04:58 PM   #11
Theo's Avatar
Thank you guys. I have a lot to learn about this beastie..
Theo
Old 01-13-2004, 08:30 PM   #12
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Spice rack tambour
The spice rack in my '77 Excella 500 was missing the tambour cover. The frame around it is off-white and so is the tambour overhead housing the instrument panel. I would suspect that this is the same color as it came from the factory. Can anyone verify this for me?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-13-2004, 09:02 PM   #13
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
David,
You are correct. The spice rack and control panel Tambour was white in the 77's
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
