Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-18-2008, 11:15 PM   #1
Upgrading piece by piece
Stella's Avatar
Profile:  1967 22' Safari
Jackson , Wyoming
Removing fabric-y stuff from compartments
My 1967 Safari has canvas fabric stuff glued onto the wooden overhead compartment cabinet doors. I know this because it's coming off in one spot.
Can I remove all of this and take it back to bare wood to match the front cabinets? Unfortunately, the wood underneath the fabric looks way reddish compared to the other original medium tone wood.
I guess the other possibility is trying to patch this fabric, but I'd rather get the wood.
Thanks!
“You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose.” -- Dr. Seuss
Life's an adventure! http://www.lovenewsjh.blogspot.com
Stella is offline   Reply With Quote
Old 02-18-2008, 11:18 PM   #2
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
on our 69 the PO had removed the covering on ours already, but those were a different grade of plywood then the cabinets (no veneer) so we ended up sanding and painting them.
goransons is offline   Reply With Quote
Old 02-18-2008, 11:18 PM   #3
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Send a message via Yahoo to soldiermedic
Hey Jo,
Those years had the vinyl wrapped wood. I had them in our 68 Safari. Not the prettiest to look at. I suppose you could remove the vinyl, but it will take alot of time, and then the left over glue would have to come off the wood for finishing. It would be easier IMHO to take the door off, and cut a new piece of wood to fit for the door. Connect it to the old mounting hardware and a nice new door (In your hand picked paint or stain color no less!)
Steve
soldiermedic is offline   Reply With Quote
Old 02-19-2008, 12:42 AM   #4
Stella's Avatar
Jackson , Wyoming
You're right, it does look like different wood. Hmm.
Another idea I had was to replace the doors with a resin panel, a la the CCD models. THis company, 3form, has a ton of cool designs. I don't know how difficult it would be to attach hardware, so my original idea was to leave 1-2 inches around the perimeter of the door with hardware attached (vinyl stripped, wood sanded down, stained or painted if need be) and insert these panels by screwing them down with hardware to the back of the doors.
I know there are no new ideas under the sun, but I wonder if anyone has tried this.
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 11:20 PM
Lower Compartments - orientation of locks philippes Classic Motorhomes 1 07-25-2007 10:33 AM
Removing Air Pump & Stuff swebster Mechanics Corner - Engines, Transmission & More... 6 03-10-2004 07:23 PM
Need Dometic RM-47 Door Compartments gsymes Parts Archive 7 01-24-2004 07:37 PM
Battery weeping outa the compartments Kistler Our Community 4 06-16-2003 09:39 PM
