Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-03-2004, 04:06 PM   #1
Profile:  1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
removing counter top
I am replacing my original counter top (any one want it) and having a stainless on made. I can't figure out how to get if of from around the stove.
Come take it off for me and you can have it along with a few nickel slots compt! LOL!
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 09-03-2004, 04:45 PM   #2
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
remove the stove.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 09-03-2004, 11:03 PM   #3
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Like Janet says. Pull the stove. The appliances are about hte last thing in. It is going to be bolted to the counter more then likely and hiding some of the fasteners that hold the counter to the cabinets. Fact of the matter is on my coach the cabinets were made and then installed the top is so much of the structure that it will just about have to completly disassembled to free the counter top from the rest.
If you just putting on new formica it can be done over the original as long as the original is still bonded to the wood. You need to sand the shine off the original fomica to give it some texture for the adheasive. I used a palm sander and 120 grit when I redid the counters in my house. Still look perfect.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-04-2004, 12:28 AM   #4
spinolio's Avatar
Profile:
Exactly what I did in my 310 MH, no problems yet. Make sure you use a serious contact adhesive, not the stuff they sell at Home Depot, go to a laminate supplier.
(no longer)on the road...
www.curtandmandy.com
spinolio is offline   Reply With Quote
Old 09-04-2004, 09:15 AM   #5
Las Vegas , Nevada
Tanks folks. I was hoping for an easier way. I am having a counter top make of stainless and a back splash, left of the stove and SS dinnet top.
Old 01-12-2006, 03:28 PM   #6
Profile:  1969 25' Tradewind
Barstow , California
Counter Maneuvers
Glad I spent the time to find this thread - I was just about to post a completely new one 'cause I couldn't find the info I was looking for: just to clarify the removal of the stove (stove top or whole thing?) in order to replace the counter top:
Is this also what one would do when replacing just a portion of the counter due to water damage? I was considering just whacking out the damaged part, adjacent to the backsplash (would post a picture but she's at the trailer doctor at the moment). Is this suggested or would it be prudent to just replace the entire countertop? Anyone have pix of the removal process, by the way? Thanks!!
lianimals is offline   Reply With Quote
Old 01-12-2006, 04:55 PM   #7
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
You might find the old countertop plywood a bit "weak"....
Originally Posted by lianimals
.....what one would do when replacing just a portion of the counter due to water damage?
When I redid the 345 counter top I retained the original plywood counter top, reinforced it from the underneath with 2 X 4's, 2 X 2's, and plywood, and put the new "top covering" over the old wood.....came out with about the same weight as compared to cutting a totally new one from scratch, and I think I saved a bunch of time by not having to trim and fit a new underlayment for the countertop.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 10:19 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 10:26 PM
resurfacing bathtub and counter top davidlaxson Sinks, Showers & Toilets 14 09-23-2003 02:30 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 09:39 PM
Re-Laminating Kitchen Counter Pick Cabinets, Counter Tops & Furnishings 4 05-24-2002 08:38 AM
