Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 11-08-2007, 09:50 AM   #1
Grand Master's Avatar
Profile:  1963 24' Tradewind
Anderson , Indiana
removing cabinet latch knobs
What is the "secret" to remove the cabinet latch knobs on a 63 / 64 vintage Airstream. I want to refinish the cabinets but can't figure out how to remove the knobs.
These are the round silver knirled knobs.
Mike Brumback
1963 Airstream Trade Wind
1959 Porsche
Anderson, IN
Grand Master is offline   Reply With Quote
Old 11-08-2007, 10:36 AM   #2
GreatPumpkin's Avatar
Profile:  Currently Looking...
Colville , Washington
Images: 70
Mike Brumback
1959 Porsche
Anderson, IN
On my '64 there are two different kinds of knobs. One is a larger, aluminum knob that you turn right? to open the door. Those you can remove by screwing the knob to the left. It will unscrew, and then you can remove the rest of the latch from the backside of the cabinet by removing two screws.
The other knob appears to be chrome plated steel knobs. They are smaller, and you latch and unlatch by turning it 90 degrees. They are a little more difficult to remove. Not hard, just more difficult than the large ones. They are held in place by the same part that enables them to latch. These have a little roll pin that you have to drive out. Be careful when you do this, as the knob also has a spring in it. Once you get the roll pin out, you don't want the spring to pop out and lose it.
I wasn't able to reuse the roll pins so I had to purchase new ones the right diameter. They were too long, so I also had to cut them off. Make sure you get them the exact same length, or it will cause problems opening and closing the cabinets.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Cabinet latch for 1970 AS FrenchBern Cabinets, Counter Tops & Furnishings 13 06-11-2008 07:44 PM
Cabinet latch substitutes? sepezlover Cabinets, Counter Tops & Furnishings 1 05-20-2006 11:47 PM
1964 cabinet latch knobs walter1 Parts Archive 2 09-07-2004 09:43 AM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 11:19 PM
