Old 08-02-2011, 12:24 PM   #1
1968 22' Safari
goshen , Utah
Refinish wood in a '68 safari
I need to do something with the wood paneling. It is getting dry and bleaching. I though about lightly sanding and coating with something. Any suggestions?
series2a is offline   Reply With Quote
Old 08-02-2011, 03:46 PM   #2
1963 19' Globetrotter
Moline , Illinois
Can you post a picture of what you have?
63air is offline   Reply With Quote
Old 09-13-2011, 12:39 PM   #3
Murphree's_Law
bamurphree's Avatar
1967 22' Safari
1966 26' Overlander
Mt. Holly , North Carolina
I am completing refinishing all the wood in my 67 Safari. It has been a big job but worth it. The veneer on the plywood is thin so be careful not to sand too much. I used furniture stripper to remove the old finish then used Minwax Golden Oak stain and sealer. I topped it with an oil base clear polyurethane and on some parts I topped coated with a new product from MinWax called "matte finish" that was a water based polyurethane. After applying the 3rd coat of the matte finish, I liked it much better than the oil base poly and found it was easier to apply and more forgiving. The label says sanding between coats is not necessary but the water based poly does raise the grain of the wood slightly so if you do decide to sand between coats, you may want to avoid avoid using steel wool. Steel wool particles left behind will rust when the water based poly is applied.
bamurphree is offline   Reply With Quote
What kind of wood was used in 1967 Safari bamurphree Upholstery, Blinds, Walls & Interior Finishes 15 10-17-2013 02:10 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
Feast of Spring Rally at Penn Wood Airstream Park PA Camper WBCCI Rallies & Events 0 04-06-2011 06:14 PM
