08-31-2011, 02:16 PM
1964 19' Globetrotter
OH - Ohio
, waynesville
Pretty backsplash
has anyone ever tried to tile the walls around the kitchen sink. I really want to put in glass 1" tiles but I'm concerned that the movement of the trailer will shake them loose. i wonder what would happen if I used caulk instead of grout. would it provide better adhesion and flexibility. OR.....should I just forget the whole thing
08-31-2011, 03:16 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I was thinking of doing the same thing. I think the Trempro(caulk) would allow one to do this, but I am not sure. I will be anxiously watching for additional comments.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
08-31-2011, 03:27 PM
OH - Ohio
, waynesville
that's perfect....maybe I'll just wait till you do it first and see how it goes. Would you use the caulk behind the tile as well, or just in the grout line? dying to make this work. hope we get some good advice.
08-31-2011, 03:56 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
I would recommend Polyseamseal Tub & Tile Adhesive Caulk. It's not silicone based and has excellent adhesive qualities. The Tub and Tile version also has extra mildew inhibitors. The main thing is to get the surfaces clean to insure adhesion. You will need to use it between the tiles and the mounting surface to hold the tiles, just the gaps where the grout would go will not do. Also, you'll need to coat the back of glass tiles so nothing, including bubbles in the adhesive, shows through.
Vaughan
08-31-2011, 04:27 PM
1967 20' Globetrotter
denver
I had some leftover 1x1 tiles at home that I used in a small area near the stove. I needed to cover up the area where I removed the original backsplash.
I used a scrap piece of aluminum as the backing and glued the tiles onto it with no grout seams. I simply butted each tile next to each other and it has traveled fine. It is a small area but without the grout lines, I haven't had any issues.
It added nice color and was cheap!
BTW, I think glass is one of the heavier material choices.
08-31-2011, 04:36 PM
1994 30' Excella
Mississauga
, Ontario
All ceramics add weight to the trailer. I'm a general contractor so have experience with tile etc.
For the backsplashes I would recommend using an epoxy grout. It is extremely strong. If you use something like kerabond with keralastic it would not likely fail if bonded to aluminum walls.
Again, remember you are adding substantial weight to the trailer.
Mine came with 12x12 ceramic tile floor in the kitchen and bath areas. When I get to it I will remove it and install something like Cork flooring to save weight.
Gasoline keeps going up in price. We should reduce weight, not increase it if we want to save fuel and be environmentally friendly. Don't really know how we can think that towing a trailer for pleasure is environmentally friendly but that's the way it is.
Al
Al and Jean
TAC ON-3
08-31-2011, 06:47 PM
OH - Ohio
, waynesville
great info....thanks everyone. So, each 12x12 tile weighs 3.25 lbs. I would need to use approx 6, so about 20lbs with adhesive. is this a deal breaker? star kitty convinced me that it looks great. maybe I should reduce it to a smaller area like you did. most of the area is window, so it's tempting to go big. will post pics when i get it done. The bathroom has been removed, so i have a little weight loss there (not planning to replace it) should i concern myself with adding 20lb to the other side of the camper for balance?
08-31-2011, 07:27 PM
1982 34' Limited
Brunswick
, Georgia
The smaller tiles will be less likely to crack. You can use liquid nails to adhere the tile to the wall, then the epoxy grout like Al suggested. I have been looking at tile at the backplash on my rig as well.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
08-31-2011, 08:03 PM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Here is a link to a recent thread about the same topic. We did the small glass tiles with good results.
http://www.airforums.com/forums/f38/...ulk+glass+tile
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
09-01-2011, 07:41 AM
OH - Ohio
, waynesville
I like those too. how does the weight compare? I'm thinking they might be lighter than the glass. would you install them the same way?
09-01-2011, 09:40 AM
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
The latest issue of Airstream Life features a trailer that used tile for the backsplash and the bath. It describes the grout he used.
