Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-24-2006, 01:12 PM   #1
wlj1943's Avatar
Profile:  1970 18' Caravel
1995 30' Excella
Mulino , Oregon
Plastic Hinge source for Cerritos built units
Hi all,
I did a search on plastic hinge material on the forums and came up with no matches after hours of reading threads; so I will try the power of the forum!
Here is my problem. After 36 years the plastic hinges on my storage bin covers on the Caravel are all almost at once beginning to fail leaving now 3 and soon four free floating pull down doors .
Last year I talked to some other vintage owners at the Brooks (OR) outing and discovered by inspection of a Jackson Center built 1971 unit his hinges and covers were slightly different, (enough so they might not easily interchange) and also noted some had used metal piano hinge which to me was not a good solution. Any suggestions out there? The hinge is asymetrical as it bends only on one edge and folds up smooth so both door halves slide in out of the way. I found one plastic hinge manufacturer on the internet that could run off a custom batch; I am willing to do this if others are interested or better yet maybe we could talk Steve at Vintage or Andy at Inland into participating if there is no there is no other source. I await the power of the forum, and please send me a private message if someone wants me to post some photos.
WLJ1943
wlj1943 is offline   Reply With Quote
Old 09-25-2006, 01:26 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Can you post a picture of your existing hinge for those of us with possible "ideas" but not a 1970 model to refer to?
May help get a better response...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 09-25-2006, 07:07 PM   #3
Profile:  1960 24' Tradewind
Riverside , California
plastic hinge
Originally Posted by wlj1943
Hi all,
WLJ1943
How about these?
Surface-Mount Piano Hinges For information about hinges, see page 2840 . Don't see the piano hinge you need? Just tell us what you're looking for and we'll get it for you.
Load-Rated Piano Hinges with Bearings and Holes A B Not your ordinary piano hinges, these are load rated for heavy doors and have nylon bearings spaced along the length of the hinge—the weight of the door is evenly distributed on the bearings for smooth door opening. One leaf mounts to the edge of the frame; the other mounts to the door surface or edge (see below). Ideal for replacing butt hinges on new and existing doors. Reversible for right- and left-hand doors. Pin is stainless steel. Can be cut with a band saw or hacksaw. From the folded position, the range of motion is 180° . Fire rated for 90 minutes for hollow metal and composite core wood doors. All have punched and countersunk mounting holes. Furnished with #10 screws; Style A also comes with #8 x 3/4" fasteners. Max. Leaf Pin Knuckle Mounting Max. Door Min. Cap., lbs. Lg. Thick. Dia. Lg. Frame Door Thick. Clearance† Each Steel— Prime Coat Finish A 6007 ft. 1/16" 1/4"1 7/8"EdgeSurface1 3/4" 1/8" 14225A22 $176.16 Type 304 Stainless Steel— Dull Finish A 6007 ft. 1/16" 1/4"1 7/8"EdgeSurface1 3/4" 1/8" 14225A24 278.90 B 6007 ft. 1/16" 1/4"1 7/8"EdgeEdge1 3/4" 3/8" 14225A26 342.77 † Minimum clearance between frame and door.
Load-Rated Aluminum Geared Hinges Without Holes With Holes Instead of having pins and knuckles that could bend or shear, these aluminum hinges are geared with nylon bearings to minimize door sag and deflection. Plus, they're load rated to handle heavy doors. The weight of the door is evenly distributed on the bearings, which are spaced along the length of the hinge—the result is smooth, easy door opening. Hinges surface mount. From the folded position, the range of motion is 180° . Without Holes— Weld in place or drill holes for screws. With Holes— Excellent for replacing butt hinges, they're also used anywhere a door has been ripped out of the frame. Hinges have punched and countersunk holes. Furnished with snap-on security molding and #12 and 1/4" screws. Cap., Daily Leaf Min. Anodized Finish Bronze Finish lbs. Openings Lg. Thick. Clearance†Each Each Without Holes— Capacity based on use with doors up to 2' Wd. x 4' Ht. 12114' 1/16" 1/32" 1381A33 $62.03 —— —— With Holes— Capacity based on use with doors up to 3' Wd. x 7' Ht. 160806'11" 1/16" 1/32" 1382A18 150.26 1382A19 $203.41 320806'11" 1/16" 1/32" 1382A23 183.61 1382A24 219.23 † Minimum clearance between frame and door.
Plastic Piano Hinges without Holes 1 1/2" Open Width 2" and 3 1/2" Open Widths A lighter weight, more corrosion-resistant alternative to metal piano hinges, these plastic hinges have rigid leaves and a flexible elastomer middle instead of a pin. The pinless construction results in smooth, silent operation. There are no mounting holes—surface mount hinges with adhesive, screws, nails, or other fasteners. Can be cut with a hacksaw. The 1 1/2" open width hinges are for indoor use; the 2" and 3 1/2" open width hinges are for indoor and outdoor use. All have a white middle, except for 11195A11 , which has a clear middle. From the folded position, the range of motion is 360° , unless noted. Temp. range is 45° to 150° F, unless noted. PVC— Leaves are PVC; this material is the most widely used vinyl, but has poor impact strength. Acrylic— Leaves are clear acrylic; this material has good clarity, but poor impact strength. PETG— Leaves are clear PETG, which has excellent clarity and good impact strength. Open Leaf Middle Clear PVC White PVC Clear Acrylic Clear PETG Wd. Lg. Thick. Material Each Each Each Each 1 1/2"6 ft. 3/32"Polyester 11195A41 º$8.83 11195A42 º$9.29 11195A21 $7.36 11195A11 ‡$36.00 2"6 ft. 5/64"Polyurethane 11195A43 13.30 11195A45 14.10 11195A22 11.67 11195A12 11.67 3 1/2"6 ft. 3/32"Polyurethane 11195A44 23.03 11195A46 24.33 11195A23 20.27 11195A13 20.27 º From the folded position, the range of motion is almost 180° . ‡ Leaf thickness is 1/8". Max. temp. is 100° F.
Harsh-Environment Plastic Piano Hinges without Holes Made of tough polyolefin plastic, these hinges resist saltwater, oil, most chemicals (including solvents), temperature extremes, and damaging UV rays. All of the hinges have rigid leaves and a flexible webbed middle instead of a pin. The pinless design results in smooth, silent operation. There are no mounting holes—surface mount hinges using adhesive, screws, nails, or other fasteners. Can be cut with a box cutter or razor. For indoor and outdoor use. From the folded position, the range of motion is 360° . Temperature range is -40° to +180° F.
To Order: Please specify color (black, gray, or white) and length from those listed below. The last length listed is the maximum continuous length. Available Leaf 1 1/8" Open Wd. 1 1/2" Open Wd. 2" Open Wd. 3" Open Wd. Lengths Thick. Per Ft. Per Ft. Per Ft. Per Ft. 4', 8', 25' 1/8" 1588A71 $2.49 1588A72 $2.93 1588A73 $4.30 1588A74 $6.22
Slip-Over Panel Plastic Piano Hinges PVC Polypropylene Acrylic and PETG No need for nails, screws, glue, or cement to mount these hinges; their leaves are ribbed channels that you press onto panel edges for a snug fit. All have rigid leaves with a flexible elastomer middle instead of a pin. For indoor use. From the folded position, the range of motion is 180° , unless noted. PVC— Leaves are PVC; this material is the most widely used vinyl, but has poor impact strength. To Order: Please specify hinge color: clear or white. Polypropylene— Leaves are polypropylene, which has good impact strength. Middle is the same color as the hinge. To Order: Please specify hinge color: black, dark brown, or white. Acrylic— Leaves are clear acrylic; material has good clarity, but poor impact strength. PETG— Leaves are clear PETG, which has excellent clarity and good impact strength. For Panel Open Leaf Thick. Wd. Lg. (A) (B) (C) Thick. Each PVC with White Polyester Middle— Temp Range: 30° to 150° F 1/4"1 1/2"6 ft. 19/32" 15/32"1 1/4" 1/16" 11565A35 $11.88 Polypropylene w/Polypropylene Middle— Not Rated for Temp. 1/8"1 5/32"6 ft. 17/32" 3/8" 27/32" 3/64" 1793A61 • 8.10 3/16"1 1/16"6 ft. 31/64" 3/8" 27/32" 3/64" 1793A62 • 7.67 • From a flat position, the range of motion is 90° .For Panel Open Leaf Thick. Wd. Lg. (A) (B) (C) Thick. Each Polypropylene w/Polypropylene Middle— Not Rated for Temp. (Cont.) 1/4"1 5/32"6 ft. 17/32" 3/8" 27/32" 3/64" 1793A63 •$8.13 Clear Acrylic w/White Polyester Middle— Temp. Range: -40° to +150° F 1/4"1 5/16"6 ft. 1/2" 1/2"1 5/16" 1/16" 11565A11 12.14 Clear PETG w/Clear Polyester Middle— Temp. Range: 45° to 100° F 1/4"1 7/64"6 ft. 7/16" 7/16"1 7/64" 3/64" 11565A12 26.67 2846
ZoomZoom is offline   Reply With Quote
Old 09-30-2006, 01:38 PM   #4
wlj1943's Avatar
1995 30' Excella
Mulino , Oregon
Shari
InsideOut,
I was gone for a while, and forgot to post the photos. I will do this soon after I reduce them to meet the forum requirements. I think ZoomZoom may have found the solution
Old 09-30-2006, 01:45 PM   #5
wlj1943's Avatar
1995 30' Excella
Mulino , Oregon
Talking Thanks ZoomZoom!
Thanks ZoomZoom. I totally forgot about Mcmasters/Carr; I used to buy from often them when I was with GE. It looks like they have a good solution that will nearly duplicate the original in appearance. I will post the photos of the existing hinge in a day or two after I reduce the size to meet the forum requirements. Good job!!
Way Cool; the forum really works!!
WLJ1943
Old 10-01-2006, 12:58 PM   #6
wlj1943's Avatar
1995 30' Excella
Mulino , Oregon
Plastic Hinge Photos.
Hi to all,
Attached are the plastic hinge photos from the Caravel. The door panels are all 3/8" thick. Some of the Jackson Center units I have seen that were built later in the 70's used 1/4" thick material if my memory is correct. You can see how the hinges were attached- good old-fashioned staples.
PS: I will be on the road for a month, leaving next week, (including a stop at Jackson Center) with the Excella, doing what Airtreamers were intended to do. Thanks in advance to all for any suggestions that you may have.
WLJ1943
ID:	26461   Click image for larger version
Old 02-21-2009, 10:12 PM   #7
Vince & Virginia
Towster's Avatar
Profile:  1969 21' Globetrotter
Did anyone ever find a source for these plastic hinges?
Mine are also failing, and the duct tape I used in an emergency is failing, and it's time for a more permanent solution.
I have a 69 and my hinges look the same.
Virginia
Towster is offline   Reply With Quote
Old 02-22-2009, 06:29 AM   #8
Profile:  1977 31' Sovereign
McHenry , Illinois
Any plastic hinge will have a limited lifetime. They will all fail due to either fatigue or simply aging or exposure to uv or ozone. It is in the nature of any plastic. Of the ones I have engineered, well designed Impact modified nylon hinges made by secondary cold forming have lasted the longest at about 10,000 cycles or ten years. Metal piano hinges work the longest but are ugly. Installing them so they are less visible is an answer.
Old 03-02-2009, 10:53 AM   #9
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
See Outwater.com Outwater Plastics - Master 2008 Catalog - page 295
Have never used them ,but they have a wide selection
Paul
Troy MI
63 Safari
97 34' front kitchen
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 03-03-2009, 06:24 PM   #10
wlj1943's Avatar
1995 30' Excella
Mulino , Oregon
Thanks Airstream 4. I will give them a try and reply on how this works; it looks very similar to the original. For the others, I did repair one door with a piano hinge. You need an accurate router table and/or a joiner to rabbit for the hinge thickness, and have to route out where the two 1/2's meet to clear the hinge pins and socket. I then added plastic slide guides over the hinge area so it would slide smoothly on the wood. Sorry I forgot to take photos, but to do one door took about 3 hours; plastic hinge replacement would be about 10 minutes I think. I agree with Dwightdi that plastic hinge life is low and time limited. I will order some and try it, will post results when done. Is this forum great or what?? Cudos to ALL!!
WLJ
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 02:16 AM
WBCCI and local Units Stougard WBCCI Forum 58 02-28-2006 09:46 AM
Door hinge bjstewart1 Doors & Locks 0 10-09-2002 07:22 PM
Plastic Shroud by Tounge? cotopaxitwo Cleaning, Stripping & Polishing 1 09-17-2002 09:29 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 07:44 AM
