Old 04-11-2015, 12:55 PM   #1
humboldtair's Avatar
Painting shower tub and sink
Name:	ImageUploadedByAirstream Forums1428778453.571919.jpg
ID:	236075Click image for larger version
Name:	ImageUploadedByAirstream Forums1428778473.620212.jpg
ID:	236076Click image for larger version
Name:	ImageUploadedByAirstream Forums1428778499.259198.jpg
Just got a 1982 airstream motorhome! So so so excited. It's in awesome condition but has some yellowing. I'd like to paint the sink and shower stall area but I'm not sure what product to use.please help!
humboldtair is offline   Reply With Quote
Old 04-11-2015, 02:32 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Lots of people on this forum recommend Krylon Fusion. It is formulated for plastic surfaces. I'm in the process of preparing my 81 Excella to do the same thing. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 04-12-2015, 05:55 AM   #3
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
MClick image for larger version
Name:	ImageUploadedByAirstream Forums1428839680.657081.jpg
A vote for Krylon Fusion for Plastic. We used it on everything with great success!
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is online now   Reply With Quote
Old 04-12-2015, 07:29 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are several 2 part epoxy finishes. They set up mirror smooth and are very tough. No special equipment needed except a respirator.
Old 04-12-2015, 11:02 AM   #5
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Dealing with the same problem with our 72 Overlander.. It just looks used,, drab and old.. I got some Fusion paint for our sun faded UTV ( atv side by side) but have not tried it yet.
So I would think a hard scrubbing,, and prep work to get all the soap oils off but what else? Would a lite pass with some 600 or 800 wet sanding be in order to help the paint stick? Then use a prep cleaner and dry?
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-12-2015, 06:52 PM   #6
Mixter's Avatar
1976 27' Overlander
Originally Posted by Paddledipper View Post
MAttachment 236113
Hey Paddledipper- how long has it held up so far? Any signs of cracking, chipping or peeling?
Seems like WAY easier, faster and less mess than the 2 part epoxy I was going to do....
Mixter is offline   Reply With Quote
Old 04-12-2015, 07:28 PM   #7
1978 Argosy 24
MooreHaven , Florida
I just last week painted the shower pan& the panel the shower knobs are on plus the sink and the platform the toilet sits on.My wife had previously painted some plastic chairs with Krylon for plastic and they didnt hold up well,of course they are outdoor chairs so maybe its better indoors.
Having always had good results with Rustoleum products i found that Rustoleum now makes a primer for plastic that you can overcoat with regular Rustoleum paints.I scrubbed with "Purple Power" using a 3Mabrasive pad to remove surface contamination then wet sanded with 320 grit then a light coat of primer,sanded lightly with 600 wet.Next day i applied a light tack coat and then 2 heavy coats of Rustoleum Epoxy appliance enamel.Painting in temps in the high 80s the paint really dosnt get time to really flow out perfectly smooth it still looked darn good,a little very light sanding with 1000 grit wet and a quick rub with some fine rubbing compound and i ended up with an excellent finish.
Only time will tell about durability,Epoxy paint is tough so i believe it will be more durable than most.
I used a color called "biscuit" available at Lowes for less than $4 that seems to be a perfect match for the original color on all these parts that had turned yellow.Hope your results are as good!
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 04-12-2015, 10:21 PM   #8
1977 27' Overlander
1996 34' Excella
We have had it in place for about 7 months with an average of one camping trip and cleaning per month. Because it melds with the plastic there has been no flaking, peeling or wear at all. There are some areas I wish I had coated a bit better but only for aesthetics. I would go this route again without hesitation.
The Evans' Family
Florida Panhandle
Old 04-17-2015, 07:46 PM   #9
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Tomorrow is the day, for me, been prepping the shower pan, medicine cabinet , toilet this winter. Finally warm enough to refinish tomorrow, 70 degrees forecasted. I am using POR White Coat that I had tinted gray, planning on putting it on with a foam roller and for the tight areas a foam brush. All cracks have been fixed and all areas sanded. Just need to wipe down with wax and grease remover, and get busy.
Never worked with this product in the past hopefully it works out as planned.
larry b is offline   Reply With Quote
Old 05-05-2015, 07:22 PM   #10
Airbiscuit's Avatar
1978 Argosy Minuet 6.7 Metre
Lorain County , Ohio
Send a message via AIM to Airbiscuit Send a message via Yahoo to Airbiscuit
We are getting ready to fix our bathroom sink... which has been repaired previously. SO I am following along here to see how well all this does to see if we should follow suit and try this route! Thanks everyone for your updates as you go!
Air # 36711
TAC- OH 6
Airbiscuit is offline   Reply With Quote
Old 05-06-2015, 07:44 AM   #11
1984 31' Sovereign
charleton , Illinois
Sherwan Williams has a primer formulated for plastics. I used it with an oil based enamel top color coar. I live in my unit 9-10 months a year at work, and after 2 years it still looks like i just painted it. I'm very pleased with how tough the finish is.
jerry d is offline   Reply With Quote
Old 05-06-2015, 08:12 AM   #12
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
I have used the krylon fusion extensively in my 3 trailers, My bathroom was done well over 5 years ago and has held up great. The nice thing about the fusion is you can top coat it years later if need be if you scuff it up somehow. Here is my thread on the end cap rejuvenation that show pic of the bathroom. the thread also gives a step by step showing pics of surface prep etc...
I would like to note, I did a test spray on the end cap of my 1969 Safari where I know the end caps are gel coated fiberglass. I found that the krylon does not bond to the gel coat so when I do that bathroom I will have to mask off the upper end caps and paint just the plastic. I use Dover white Kylon fusion for the fixtures but used metallic silver for the tambour doors.
http://www.airforums.com/forums/f39/...ly-124989.html
thesignlady is offline   Reply With Quote
Old 02-06-2016, 06:11 AM   #13
gainesville , Florida
What paint product did you use on the 1969 gel coated end cap? I have a 1969 Tradewind and am preparing to paint the bathroom. Will use the Krylon on the plastic tub/sink/etc but unsure about the end cap....Thanks
jrex is offline   Reply With Quote
Old 02-06-2016, 09:03 AM   #14
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
WE used epoxy boat paint to paint our bathroom.
Cleaned it first with that white granulated cleaner por or someothing like that.
The secret was to get it clean!
Been since 2007 and still looks good.
https://www.facebook.com/jim.lee.165...1734755&type=3
Jim Lee is offline   Reply With Quote
Painting the shower pan and sink? shermantic Sinks, Showers & Toilets 2 01-25-2009 08:40 PM
repairing '65 Safari Tub/Sink/Shower chris clark Sinks, Showers & Toilets 1 03-03-2007 10:37 AM
Painting the tub and stool Judy Barde Sinks, Showers & Toilets 1 01-14-2007 06:09 PM
Painting the bathroom cabs sink/counter/tub balrgn General Interior Topics 42 10-10-2006 08:27 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
