Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-11-2007, 03:12 PM   #1
31airstream's Avatar
Profile:  1979 31' Sovereign
Granbury , Texas
Question Paint Ideas????
we want to paint these...any color ideas???? And also what is the best kind of paint to use?
Nicholle & Wes
Our Kids: Westin (3) & Pierce (2)
sassybabystuff.com
31airstream is offline   Reply With Quote
Old 06-11-2007, 04:06 PM   #2
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
The color is up to you and yoiur decorating scheme for the interior. I would clean the surface with TSP before painting. The type of paint is also up to you. Interior latex is easiest with easy cleanup. However, with two children (ages unk). you may want to use an oil base paint for better durability. Cleanup is a little more involved, however.
Probably only confused you more, but hopefully gave you some base thoughts.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-11-2007, 04:07 PM   #3
Granbury , Texas
they are 2 and 4
Nicholle & Wes
sassybabystuff.com
Old 06-11-2007, 04:09 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
From your pictures, I believe the cabinets are a laminate and the walls are vinyl wallcovering. Both are paintable if the substrate is adhered solidly, cleaned throughly and prep'd with an appropriate primer. The key is in the cleaning and prep-ing. If not done well, the paint will peel.
From your picture, it looks like the laminate may be damaged or peeling along the top edge (maybe it's just an illusion) but if it is, this would be tough to paint over without it being noticale even with all your hard prep work.
I have seen the vinyl wallcovering painted with Zolotone - it looks GREAT!
There are lots of people that have done similar projects - you may want to read through some of the older threads (search using some key words like "paint" "laminate" "wallcovering" "vinyl") until someone else replies directly.
Good luck in whatever you decide to do.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 06-11-2007, 04:13 PM   #5
Granbury , Texas
Shari
Thank you for the advice what is ZOLOTONE?
Nicholle & Wes
sassybabystuff.com
Old 06-11-2007, 04:38 PM   #6
Alumatube's Avatar
Profile:  Richmond , Kentucky
And is Zolotone appropriate for painting the plastic end caps, too?
Thanks!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 06-11-2007, 04:41 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 87
Zolatone is a very durable, high quality, multi-colored fleck paint. It was standard on Airstreams in the 50's & 60's.
Check out thier website: Zolatone
Yes, it's appropriate for palstic end caps too.
Shari
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 10:32 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 12:56 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 08:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 09:14 PM
